Question about Panasonic Microwave Ovens
I have a panasonic steam microwave and the powere inverter fault has been diplayed. Can yo helpo please 1
  • Panasonic Master
  • 9,098 Answers
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 09, 2008
HAVE A PANASONIC MICROWAVE WITH A H98 CODE THAT ISN'T WORKING. IS WORTH TRYING TO FIX?
That fault is the inverter. It has failed. Only Authorised Panasonic suitably trained engineers should attempt repair. All they will do is replace the inverter and probably magnetron as that may have been the cause.
Oct 22, 2017 | Panasonic Microwave Ovens
Tip
Panasonic error codes h97 h98
If it is displaying error H97, or h98, this generally means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnetron may also be faulty.
Here is some more information about the part. The microwave may also have a faulty magnetron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
BEWARE... VOLTAGES INSIDE MICROWAVES CAN KILL
Panasonic part number: Z606YM300BP, supersedes all previous versions of the inverter used with the 2M261-M32J This Inverter is now available at a lower cost, it used to be £60.00 plus VAT and delivery trade price.
This inverter is fitted to many of the more recent Panasonic inverter type microwaves such as the NNC596S .Some microwaves such as Bosch and Siemens also use this inverter as they are rebranded Panasonic ovens. These ovens are upmarket models, some include advanced functions such as steaming and are normally well worth repairing.
The inverter as fitted to earlier ovens with the 2M236-M42 and 2M236-M1 is also available.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
As well as the inverter failing it is also possible you could also have a defective magnetron,
Good luck and thanks for using FixYa
A FixYa rating would be spot on for this information to you.
ask
robotek
on May 07, 2008 | Panasonic NN-SN657S Microwave Oven
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
What fault is it whenH97 comes on the microwave oven
could be serious or minor fault ,have an electrician or engineer measure the the ac current AT THE MAINS PLUG
1 = OVER 1 AMP,the magnetron or the inverter power unit is faulty
2= 0.8 AMP OR LOWER,HALF AMP,problem is dpc board or the wireing to it
Replacing,repairing or testing of the inverter power unit is best left to professional engineers with acess to panasonic test procedures high voltage high current = danger of death.
if 1.5 amps or so and magnetron suspect check with continuaty tester for open circuit fillament or wireing to
Jan 11, 2015 | Panasonic Microwave Ovens
Hi, i have a panasonic inverter microwave, but stop working properly.It has power when plug-in, all function buttons are working but when it comes in microwaving, its stop automatically after 7 second
That would be an inverter issue. Here's my overview of Panasonic microwave faults:
Diagnosing Panasonic microwave oven stoppages:
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Or see if this describes what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector. If so, see:
http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
http://www.microwavecontrol.com/doorsw.htm
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the complexity and lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Got more questions? Please contact me directly for full details since FixYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Nov 25, 2017 | Microwave Ovens
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
H97
Hi there..
If it is displaying error H97, this means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnatron may also be faulty.
You can get a new invertor on ebay.UK from here
Here is some more information about the part. The microwave may also have a faulty magnatron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
regards
robotek
May 07, 2008 | Microwave Ovens
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Microwave Ovens Logo
37 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
