Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washer intermittenly doesnt spin - not all water is pumped out (response)
Thanks for the solution. Is the basket drive the same as the transmission/gearbox? I found, with further observation, that what seems to be the real problem is that it doesn't always spin. If i open the lid, and turn the basket manually, the spin cycle will work most times. Then do i need to replace the transmission or the moter assy.
    Sergeant:
    Champion:
  • 324 Answers
No the basket drive is above the transmission.you must remove the gearcase(transmission)out first,but you need to take the agitator of first and there is a spanner nut there from above.
Posted on Nov 04, 2008
Spin cycle not getting all water out
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Check that the hoses aren't blocked and, If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
May 02, 2010 | Kenmore 24902 Top Load Washer
Washer doesn't spin
let the machine rest for a long time (cool off) then with no water or clothes try spinning it...
no spin problem can be several headaches:
too much clothes (too heavy)
drive coupler broken
broken lid switch
basket freeze
pump locked
clothing in pump
clothing in between basket
clutch locked up
brake locked up
transmission seized!!!
it is hard to determine exactly without being there to help you...just check what you can... if you have additional questions let me know
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Direct drive Kenmore washer does not spin
. If water does not pump out and not spin, check lid swicth. If it pumps the water out but does not spin you could have one of the 3 following problems. Ck in this order. Drive couplin is bad between motor and transmission. usally will make a rattleing noise/chatter. Next possible clutch. While hold lid switch down with pencil or something small spin tub with hand. if it takes off and spin replace basket drive and possible clutch if doing this much tear down. last of the 3/ look around the sides of the basket holes with a flash light for something like a sock/ rag or something like that has gotten between the outer tub and basket. it is hard to see but with a good light you can see it or remove cabinit and check sides of outter tub . you can see through the tub.
Mar 05, 2010 | Washing Machines
Wcvh6600hbb ge washer does not spin.... pump is pumping out the water.
could have a problem with the basket drive tube assy,,,,what happened to mine was the brass t-post on the bottom of the basket drive tube had been ground off causing my clip that holds on the brake release arm to fall off,the arm and cam fell down and thus had no spin,,,i bought a used tube installed it with a new clutch and it works fine now! I'd check that are of machine!
Feb 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont a washer spin out when it doesnt have a belt
Hi, The coupler replaces the belt and it could have broke. Other options are, the lid switch is bad or the spin basket drive assembly or the transmission. If the coupler is broke, the washer will not agitate either. If the lid switch is bad, the motor will not run either while in spin cycle. If the spin basket drive or transmission are bad, it might spin a little but not strong enough to get the water out of the clothes.
Does nay of these sound like they are what is going on with your washer?
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore topload washer pumps water out but won't spin.
your basket drive has gone out on you.
cost high to repair
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
there is no belt, if the coupling was bad then it would not spin at all. Sounds like it could be a worn basket drive.
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
10 year old Whirpool Top Load washer
hi thanks for the question the problem you have is with a part called drive coupling which is situated on the motor and transmission replace this part thanks te appliance doc
Aug 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Series 70 won't spin
Sounds like you have got a basket drive and sub-pack issue. These are very hard to change out because it requires you to remove the inner basket, motor, transmission, agitator, pump, etc. The part number for these are:
Clutch Kit (Sub-Pack): 285785
Basket Drive/Spin Tube: 285792
If you think your up to the task, let me know and will send you some general info on getting the stuff in and out. Good Luck!!!!
Feb 02, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
