Question about Jenn-Air 35 in. JEC9536ADS Electric Cooktop
Wiring a jec9536bdb cooktop
Can i use a 220v 2-wire feed for the ccoktop, or does it need to be 220v 3-fire supply?
  • 76 Answers
You need a three wire or two as long as you have the two hots and ground. dont skimp on wire size though. hope this helps
Posted on Nov 04, 2008
Power needs for Cooktop
You need to put a multimeter across the two wires to check it.
Mar 09, 2014 | Cooktops
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Power requirement
If you are running new wire to the cook top. You need to run 10x4 wire. The 12x4 wire is not large enough for the 220v. Also the 20 amp breaker is not large enough to run the cook top. You need to use a duel 30 amp breaker.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 09, 2010 | Jenn-Air JEC6288AAB Electric Cooktop
How to connect 4 wire into 3 wire existing box.
L1 and L2 connect to the black and red. White connects to White. Green connects to the electrical box if it is made of steel and is grounded. Otherwise the green connects to the whites
Jun 14, 2009 | Jenn-Air JED8230 Electric Cooktop
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
between white - black 220v
between white or black - ground 110
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire electric glass cooktop wiring problem
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Frigidaire smooth cooktop PLEC30S9EC
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Nov 02, 2006 | Frigidaire PLEC30S9EC Stainless Steel...
Jenn-Air 35 in. JEC9536ADS Electric Cooktop Logo
157 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
