Question about Ricoh Aficio CL2000 Laser Printer
Ricoh CL2000 Printer Problems
It started a long time ago and is getting worse and worse. I connected the printer to my xp pc using a usb cable. Every now and then when I tried to print, it would not print. I would have to pull the usb cable from my computer and plug it back in and it would start printing. Sometimes I had to power the printer off and back on. Normally only once but sometimes twice.
Recently I changed to a network cable and setup my pcs to access the printer through the nextwork. Same results. Sometimes pulling the network cable and plugging it back in would work. Other times I have to power off the printer and power it back on.
Any thoughts?
    Problem Solver:
  • 10 Answers
If you are printing PDF files, that could cuase this problem. Otherwise, if your getting the issue from two different computers its possably a fualt with the Printer.
If it is a printer fualt, there proberly isnt alot you can do with this issue. You may be able to update the firmware.
Posted on Nov 05, 2008
RICOH Aficio 3045 Necessary HELP!!! Necessary
If you go into "user tools" is there a printer and scanner option there? If not the MFD does not have the print option.... If it does you need to program the IP address sub net and gateway. -Carl
Sep 18, 2016 | Ricoh Aficio Office Equipment & Supplies
RICOH Aficio 3045 HELP!!! Necessary
If you have used various computers with different OS's and you still cannot get any to recognize the printer, then it would appear that the printer electronics are fubar.
U might check with Ricoh but ......................
Sep 17, 2016 | Ricoh Aficio Office Equipment & Supplies
I HAVE A RICOH AFICIO CL2000 LASER PRINTER AND WANT TO SELL OR GIVE IT AWAY, BUT I HAVE A CONCERN ABOUT ITS MEMORY. IS IT VOLATILE OR CAN SOMEONE GET ACCESS TO INFORMATION THAT I PRINTED OUT PREVIOUSLY?...
Hi, the CL2000 has a hard disk drive, mounted on the controller board, where image data is stored temporarily. If you're worried about sensitive data, it's a good idea to have a technician remove the hard drive before you give the printer away.
Jan 11, 2011 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Strange lack of color lines
These are actually called PCU ( photo conductor unit) and yes they can be required to be changed frequently at times. I work on a lot of Ricoh printers and this is a common issue.
Jul 27, 2008 | Ricoh Aficio CL2000 Laser Printer
Printer problems
It really sounds like you either have to reload the driver, or select a differnt driver from the Richo web site.
Often times the driver will corrupt or simply be a poor match up for the system.
I would delete the priter from the printer consol on your computer, would be in control panel under printers and faxes. And reinstall. And again, try between a PS and PCL driver for the most compatible one.
Mar 28, 2008 | Ricoh Aficio CL2000 Laser Printer
USB devices not seen
go through control panel/system/device manager, and see if the USB ports(should be at bottom) are good or not.
if not, remove them all
use scan for new hardware at top
see how that works.
Mar 28, 2008 | Computers & Internet
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio CL2000 Laser Printer Logo
140 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
