Question about Sharp AL-1217 Copier
A klicksound like a slipping gear every 4th second and no copying working
When I start the machine it never et ready to copy. It is just making a klicksound like a slipping gear evedry 4th second and it does not respond on copybutton. Sometimes it has started when I have opened the paperbox and put it in again but sometimes it does not. I have not found any reason for this behavior any time.
  • 25 Answers
Is this a laser machine that takes dry toner if it is it sounds like it is out of toner.
Posted on Nov 05, 2008
2001 Chevy S10 4x4 4L60E transmission works perfectly until 50MPH then I lose 3rd and 4th gear, 1st, 2nd and reverse are normal. Never happenend before, been parked since. Fluid is clean. Any ideas?
Are there any DTC's - diagnostic trouble codes ?in the PCM / BCM ? You have third an fourth below 50 mph but above 50 it down shifts to 2nd gear ,is this what your saying or you don't have 3rd or 4th gears at all ? Which engine did yours come with ? 2.2 L or 4.3 L You trans can set several DTC'S an not all will turn on the check engine light .
DTC B2722 (4.3 L) DTC P0218 (2.2 L) DTC P0218 (4.3 L) DTC P0502 (2.2 L) DTC P0502 (4.3 L) DTC P0503 (2.2 L) DTC P0503 (4.3 L) DTC P0705 (2.2 L) DTC P0706 (4.3 L) DTC P0711 (2.2 L) DTC P0711 (4.3 L) DTC P0712 (2.2 L) DTC P0712 (4.3 L) DTC P0713 (2.2 L) DTC P0713 (4.3 L) DTC P0719 (2.2 L) DTC P0719 (4.3 L) DTC P0724 (2.2 L) DTC P0724 (4.3 L) DTC P0740 (2.2 L) DTC P0740 (4.3 L) DTC P0741 (4.3 L) DTC P0742 (2.2 L) DTC P0742 (4.3 L) DTC P0748 (2.2 L) DTC P0748 (4.3 L) DTC P0751 (2.2 L) DTC P0751 (4.3 L) DTC P0752 (4.3 L) DTC P0753 (2.2 L) DTC P0753 (4.3 L) DTC P0756 (2.2 L) DTC P0756 (4.3 L) DTC P0757 (4.3 L) DTC P0758 (2.2 L) DTC P0758 (4.3 L) DTC P0785 (2.2 L) DTC P0785 (4.3 L) DTC P1810 (2.2 L) DTC P1810 (4.3 L) DTC P1860 (2.2 L) DTC P1860 (4.3 L) DTC P1870 (2.2 L) DTC P1870 (4.3 L) DTC P1875 (4.3 L) .
Shift Pattern This category contains the following topics:
One forward gear only
Two forward gears only
Gear missing or slipping
No upshift or slipping upshift
No downshifts
Non-First gear start
Refer to First Gear Range Only - No Upshift .
Refer to Third Gear Only .
Refer to Second/Third Gear Only or First/Fourth Gears Only .
Refer to Slips in First Gear .
Refer to Slipping or Harsh 1-2 Shift .
Refer to No 2-3 Shift or 2-3 Shift Slips, Rough or Hunting .
Refer to No 3-4 Shift, Slips or Rough 3-4 Shift .
Refer to No Part Throttle or Delayed Downshifts .
Refer to Second Gear Start .
Feb 18, 2016 | Cars & Trucks
Gears slipping
Sounds like early stages of a worn out clutch slipping under load. If it is, make sure in the future to always take your foot completely off of the clutch pedal once in gear, or you will be replacing it again. In other words Do Not Ride the Clutch. Eventually you will have trouble going up hills, even in first or second.
Nov 14, 2017 | 1996 Toyota RAV4
1995 chevy blazer transmission will not let truck shift out of second when in drive
Normally while driving in overdrive (4th gear) you will feel it start slipping and finally slide into third gear. Then 3rd gear slips out into second, and you will never see 3rd or 4th gear again. I'm guessing this was the problem? If so its time for an overhaul
Dec 22, 2009 | 1995 Chevrolet Blazer
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
How to color copy
c'est une phtocopieur noir et blanch
Jun 27, 2008 | Office Equipment & Supplies
Error F89-2
bad controll board
May 27, 2008 | Office Equipment & Supplies
: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Do you have a AR-LC4 attached to the machine, if you do make sure that it is attached securely and level.
If that doesn't work, check your developer unit looking at the drive gear in the back of the unit.  Turn the gear and make sure that it turns the mixing paddles without slippage.  If it slips, replace the gear.
If it turns everything okay then check the mixing paddles it self to make sure that none of them are broken and not getting toner to the developer, if they are broken replace them or replace the whole developer unit and developer.
Oct 26, 2007 | Sharp AR-651 Copier
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
