I reset my sylvania three times now. Everytime I start it up it runs fine for about45 seconds and then freezes again. What do I do?
It seems alot of people have had similar issues with these PC's.
Sounds like it could be a virus or registry error. But could also be a hardware error. Does the machine run hot? If so, try cleaning the vents and running it on a hard, flat surface. If that doesn't work I would try running an anti virus and/or anti malware program (in safe mode if that's on option) If that doesn't find anything, then you could try reinstalling the O/S.
Is there a recovery partition on the hard drive?
If none of the above works, then it is probably a hardware issue, hard drive or RAM error, something like that.
SOURCE: Notebook smells like burning plastic.
The Averatec 3200 PC Notebook is equip with a power module that connect the ac power adapter to the notebook and charges the battery. When this small circuit board shorts or become defective in any way it fails to charge the battery and you will smell smoke due to the poor connection. By replacing the power module it will resolve your isssue. RON
SOURCE: sony pcg frv 37
Well there are some things that might help you with this...
Here are some ideas...
and get a newer one :)
SOURCE: Acer 5050 notebook, starts-up and starts-up
Hey,
if you never get to the windows screen, then the computer is unable to start up and automatically restarts.
to fix this issue you need a windows installation cd or a the recovery media that came with the computer when purchased.
if you don't have either I suggest you take the computer to a professional who owns the cds and he or she can fix it for you.
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: having problems starting my laptop. it starts
Try booting into "safe mode". by taping the f8 key while it is booting. If it runs ok there it may just be a video driver, as this is what it sounds like. If you have the same problem in safe mode, you have either a virus or spyware program that's in one or more files. If that's the case go back to sae mose, and run a good virus cleaner and spyware sweeper, Avg makes a free version, and Spyware search and destroy , and run that also. Try the video driver first, it may be a combination of both, that's one of the problems of doing a blind repair like this, we sometimes have to try a few things before nailing the correct problem. But it is more than likelly one of those two, good luck
SOURCE: Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
