Question about Navigon 2120 GPS Receiver
Navigon GPS My GPS will not turn on. Battery is fully charged, power cord plugged in, but will not turn on. This is the second time in three months that i have had this problem. The first time it was sent in and repaired. It took about 3 weeks to send it in and get it back. I work for COMCAST and use it all day every day, and this is becomming a huge inconnvinience.
Where did u get it fix because i have the same problem my green light says is on but i can turn on my screen and i also try to reset it but it wount let me do any thing
Posted on Nov 04, 2008
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
My navigon 2110 max gps will not power up. It is fully charged. It will light up for a second then go out.
Please slide the power button to the left and hold it in that position for 10 seconds.
This should reset the device and force it to power on.
Dec 19, 2009 | GPS
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
GPS signal not sufficient on iPhone 3G
Had the same problem with Navigon for the iPhone. I found a simple quick fix:
1. Go to your iPhone Settings
2. Press the General tab
3. Scroll to the bottom and press the Reset tab
4. Press the Reset Network Settings tab
This may take a short time, then after it's done, reboot your device (if it doesn't on its own).
You should now have a good GPS signal!
Jul 05, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
My Navigon 7100 doesn't turn on! It does get charged though...
I had a similar problem with my 2100Max. I took the SD card out, plug it into my computer and then reinstall it. It works like a charm these last months still.
Jun 08, 2009 | Navigon 7100 GPS Navigator GPS Receiver
I've had my Navigon 7100 GPS for 2 weeks now, little use, and today I got the fatal application error that MN6.exe was going to shut down. I have seen forums on this issue but nothing recent. The unit will...
I solved this problem.
The backup is just a copy of the files on the SD card. I made one a couple of months ago when everything was working ok. I tried to erase the SD card so I could restore the backup manually. I ran into an error with a SD card file that wouldn't erase. I ended up formatting the SD card then copying the old backup files to it. That took care of the problem and now the Navigon works the way it's supposed to.
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 5100 won't turn on when battery is charged.
try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
Nov 29, 2008 | Panasonic Navigon 5100
Navigon 2120 GPS Receiver Logo
420 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
