Televison & Video Logo
Anonymous Posted on Mar 16, 2012
By tv is stuck on standby and now wont turn on it first started with a sound like its blinking then wouldnt turn back on plse help me
Panasonic 1080i BBE Digital Tau Giga
  • Anonymous Mar 18, 2012
    Thank you SD Tech :)
    SD Tech would u have a fair idea how much this would cost to repair ? plse
Anonymous
Level 3:
Top Expert:
  • Panasonic Master 14,553 Answers
  • Posted on Mar 16, 2012
Anonymous
Panasonic Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715214
Points
48227
One or more lights on the front should blink an error code
Set likely has either a problem with its power supply board or something is pulling voltages there down--
Power supply board is the place to begin
5 Related Answers
Anonymous
  • 3459 Answers
  • Posted on Apr 18, 2010
SOURCE: convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Anonymous
  • Posted on Jun 24, 2010
SOURCE: I have a panasonic Tv 1080i it wont turn on, there...
tv will not come power light just flashes red
Anonymous
  • 101 Answers
  • Posted on Dec 18, 2010
SOURCE: panasonic cinemavision hdtv 1080i projection TV.
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Anonymous
  • Posted on Jan 15, 2011
SOURCE: Panasonic 1080i TV turns off by itself. Shuts
your bulb is burnt out,have to order new one, big problem alot for me anyway
Anonymous
  • Posted on Mar 02, 2011
SOURCE: 43" samsung rear projection hdtv SP43W6HD 1080i
you have a bulb gone i have the same problem
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
PANASONIC PLASMA HD 42 INCH WONT TURN ON JUST BLINKS 10 TIMES
10 blinks of standby light with Panasonic Plasma indicates:
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
For more details visit the site named [Electro-help" The keyword to search is "Electronicshelponline"
11helpful
2answers
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
TV off...cant get out of standby mode
Sounds like the connections on the CRT Socket or CRT circuit board. Remove back and check connections.
You could also have buildup on the cathodes of the electron gun (internally) to redimie you must have set in operation and viewing video. Tap the neck of the tube gently while watching for the colors to change until they Stabileize, this is best seen whith the color turned off.
Good Luck
I have a panasonic flat panel tv 1080i. 46" I think. When I press the power button, the red light comes on, then it starts blinking. And the TV never turns on, but the red standby light continues to blink....
the s1 models have been having several problems. it really depends on how many times the red led is blinking. panasonic uses a certain number of blinks to tell you what board has failed. the s1 models have just recently come out. therefore your tv should still be under manufacturer warranty. call panasonic and see if there is a servicer in your area. our company is in dallas texas. Aces Tv Service.
The TV will not turn on
transister on tube blew out, needs new tube, could be from storm
My ps3 is stuck on 1080p mode. i was playing on a freinds tv. my tv is only 1080i.whn its hooked up to my tv i get sound but no video plus i get nothing from the component cord short of taking back to my...
Put the ps3 into standby mode. Then press and hold the power button for five seconds. The machine will beep, and the video will be reset back to normal mode.
http://answers.yahoo.com/question/index?qid=20080621130655AAkJqSr
Tv wont turn on
3 blinks corresponds to convergence ICs
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
