Question about Giorgio Armani Samsung P520 Cellular Phone
Changing setting how do you change the silent profile to general. please help!
  • 50 Answers
Press and hold "#" key to switch between general and silent profiles. It works on most of phones. I hope this helps...
Posted on Nov 04, 2008
Motarola gp340 does not beep when switched on, can you tell me how to make it beep when you switch it on. Thanks
You will need to go into your settings (sound settings or profile settings which you are using) and enable (turn on) warning tones.
Hope this helps and please rate thanks
P.S if the profile is on silent, there will be no beep. Change profile to general and turn up volumes and enable warning tones.
Mar 23, 2011 | Motorola GP340 Two Way Radio.
My nokia N1200 cant ring or vibrate.
Hello, can you try to change the Profile, it might be on "Silent", so go to "settings" then "profile" and change it to "general"... if you can not get to that press the Please the # key for 5 seconds
GOODLUCK.
Dec 15, 2010 | Nokia 1100
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
How to switch off silent mode
To switch off silent mode please follow the below instructions
Menu > Profiles >
You will get following options in it
Normal/General
Silent
Meeting
Outdoor
Pager
Scroll through the normal/General profile and
Press select once the normal/General profile is highlighted.
Scroll to Select and press Select.
Now you are out of silent mode.
If the mobile is still in general and in silent mode then follow the below steps.
Scroll to the normal/General profile and press Select.
Scroll to Customize and press Select.
In that you will have an option called as Ringing Option.
Please set it to ringing and save the settings.
You are done
Thank You
Aug 07, 2010 | Nokia 6100
I cannot turn my silent mode off my phone -- I have A samsung
The silent mode can be changed by setting in the profile. It can be done in 2 ways:--
1) Short Press the button which u use for switch off the mobile. Long press will turn-off the mobile. So, just do a short press. Then a menu will appear, from that select the Normal/General profile.
2) Open the Profiles from the settings. It might be inside the settings Folder, may be inside subfolder. Open The Profiles and select any other profiles other than silent mode. Or you can edit the profile also.
Hope you got the solution.
Thanks & Regards
Vineeth K.
Jul 15, 2010 | Samsung SCH-a870 Cellular Phone
I have LG GM205 phone and have 2 problems.\r\n1st
Change profile to silent, then go back into general profile & select 'personalize'. Go to Keypad Tones & turn off, then click back & select 'activate'. You should now have no keypad noise and the phone should ring.
Jun 04, 2010 | Cell Phones
It is in silent mode,dont know how to change.
You will have to change the "profile." (from the home screen) press MENU, then select PROFILES, scroll to a profile (available profiles are: General, Silent, Meeting, Outdoor, and Pager) and press SELECT
Feb 13, 2010 | Nokia 6310i
Nokia 6300
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone.
Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
Apr 25, 2008 | Nokia 6300 Cellular Phone
Giorgio Armani Samsung P520 Cellular Phone Logo
47 people viewed this question
Top Giorgio Armani Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Giorgio Armani Cell Phone Expert? Answer questions, earn points and help others
