I have an Onkyo HT-R550 receiver, and last night i cranked it up loud.... Real loud. It went into protection mode, which with most receivers is as simple as turning off, then on with lower volume. Not the case with this one. It comes on, but once speakers "A" are activated, it turns off again.
simplemitch
  • 752 Answers
SOURCE: overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Posted on Sep 25, 2007
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
SOURCE: Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
Posted on May 21, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Posted on Jul 04, 2008
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
I want to use my turntable with my Onkyo HT-R550 receiver. What type of preamp should I get and where should I attach it in the back? Any suggestions are welcome! :)
HI U should have enough power in the onkyo to run the turntable...u can plug it into the rca socket marked in if u have rca plugs on you're player the in rca sockets r in between the out rca sockets & the front rca sockets ....if you're player has the old style plug u can plug it in just above the rca in socket.if u have no luck with them try the CD & tape input section under you're component video section good luck
Aug 11, 2015 | Onkyo Audio Players & Recorders
Onkyo HT-R2295 receiver turns on then off
Is it going in to protect mode?
Check your speaker wires for shorts.
Sep 04, 2014 | Onkyo Audio Players & Recorders
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
I can't get any audio from my PS3 through the HT-R550 I am trying to set up in my home. I have an HDMI cable connected/running from my PS3 into the reciever. I also have an HDMI running from my Plasma TV...
run everything to receiver each channel should work on own for audio
video to tv audio to input rca jacks
if have to much rca's for little bit of reciever input output rca's go out to walmart and buy a rca switch for sound
one side would be A the other side would be B
May 13, 2008 | Audio Players & Recorders
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Onkyo HT R550 sound going in and out
Sh$T I had the same problem with an older model... went out and bought a new Onkyo... HT-R550 I have had it for 2 years as of January 2010
Dec 06, 2007 | Audio Players & Recorders
Dec 31, 2006 | Onkyo TX-V940 Receiver
Amp Protection Mode
no, your output transistors maybe 2 of them are gone or the small power supply that feeds the other circuitry has become defective.
Dec 13, 2006 | Onkyo TX-SR503 Receiver
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
