Question about Refrigerators
Broken ice machine on a jennair refrigerator
Hi
the flap that opens to dispense the ice has a broken tab and evidently I need to replace it. How hard of a job is that, I'm relatively handy
James
Took it apart, figured out how it works and fixed it
Posted on Nov 06, 2008
Kenmore refrigerator model 106.57372700
This is usually not hard to fix. Either the tab that hold the dispenser actuator is broken or the ice guide may have come loose. Repairclinic.com has a nice video on how to fix this.
Jul 23, 2014 | Kenmore Refrigerators
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice machine flap doesn't close all the way,then stays closed
There is a ice door solenoid for your dispenser, its probably the problem. Costs about 35 dollars and just about anyone can replace it.
May 29, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator
first, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
