Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
After Drive is what : )
Hi there...thanx for your info on this harddrive. I have the HDD out of the case and notice there is a short Sata do i connect this HDD to my PC to see is it will start up and i can recover my files. p.s. my pc does have (2) sata ports (sata1 and sata2)...i did connect once but my pc wouldn't open up ( just black screen)...can you assistme?.thanx Stan ( )
  • fortifier Nov 09, 2008
    Thanx...i'll try it out
  • 95 Answers
You will need to find a SATA cable. Usually there are some supplied with motherboard.
Posted on Nov 07, 2008
Disk read error press ctr+del to restart
SATA connector cable faulty or not plugged in properly or power not available for harddrive, or read-write heads of HDD broken or damaged. If this is the case, replace HDD. tests can start by using another harddrive with working operating system, or by unplugging both power and data cables to drive, as well as the data cable from board. be sure to power off the computer
Apr 01, 2014 | ECS Computers & Internet
My Toshiba 1Tb External Hard drive Light Isn't coming on!
It sounds like the usb port on the drive itself is shot. You can actually take apart the case and pull just the harddrive out and use a hotswap usb harddrive reader and get to your files again
Dec 11, 2013 | Computers & Internet
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Hi . I have trouble with Dell optiplex GX280 . In the PATA I have two devices . DVD and HD . Both set with jumper . DVD as Slave and HDD as Master ....But the install os cannot detect HDD . where is...
I don't know where the trouble is without more information.
Some tips/information I will list, however,
1) The master harddrive that came with the computer, and has the operating system on it, is a SATA unit.
Therefore any harddrive installed along with it has to be installed as a Slave drive.
BIOS will look for the harddrive with the operating system on it. This harddrive has to be set as a Master drive. (Primary Drive in BIOS)
Installing a harddrive that is a PATA (IDE) unit, AND a PATA optical drive on the same flat ribbon cable, has to be done accordingly;
A) It depends on what flat ribbon cable you have.
There is a 40 wire cable with a 40 pin connector. (39 actually. One socket hole is not used)
There is an 80 wire cable with a 40 pin connector. (39 actually)
Proper method of connecting,
2) Proper method of using jumpers on an IDE (PATA) harddrive, and connecting the flat ribbon cable,
Jun 05, 2011 | Dell Optiplex GX280 (99301) Motherboard
How do i remove the hard drive from a hp pavilion a1320n
1) Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, computer on a table, computer case open.
TOUCH the metal fame of the open computer case to relieve your body of Static.
Also before you take new hardware components out of their anti-static bags, or boxes.
If you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
HP Support > Pavilion Media Center a1320n > Opening the computer case
Replacing the Harddrive, (Hard Disk drive),
The Harddrive is a SATA harddrive. Uses a SATA 7-pin data cable, and a 15-pin SATA power cable.
Top right photo shows the SATA data cable connector, and cable.
Top right photo below it shows a typical SATA data header (Connector) on a motherboard.
Typical SATA power cable, and it's respective connector,
IF, your SATA harddrive has a connection for a standard 4-pin Peripheral power cable, (Misnomered as Molex), AND a connection for a SATA power cable, ONLY use the SATA power cable.
It will Burn Up the Harddrive if you use both.
If you are putting a new Harddrive in, you will need to have backed up, (Copied) the info you wish to save off of your old Harddrive, first. This is if the harddrive is not bad, of course.
You will also need the Restoration Disk/s to install a new Harddrive, if you are going to just replace the harddrive with a new one. (Larger, or replacing a bad harddrive)
If you do not have the Restoration Disk/s you can obtain them from HP Support.
In the US call 1-800-474-6836
24hrs a day, 7 days a week.
Disk/s are free. Shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Have the Serial Number from the back of your computer tower handy to give to the representative.
(White Service Tag. S/N is Serial Number)
If you are not in the US, here is the Worldwide Support contact page,
If you are going to install a new operating system, per se Windows, (Windows 7?), you may have to go into BIOS Setup, and in Boot Order set the first boot device to CDROM, if the disk does not automatically load.
Oct 24, 2010 | HP Pavilion Media Center a1320n PC...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Which hard disc drive is better for pc sata or pata.
hi SATA in my opinion is better, one for air circulation also speed, and the modern motherboards can have from 2 to 6+ SATA ports, which is better than just having 2 ports for 4 items, so i would go for a SATA any day...hope that helps
Jun 16, 2010 | Hitachi Computers & Internet
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Philips freevents x52 laptop raid driver for F6
It's not easy to find info on this machine. I believe it has an Intel 945 chipset, and you can find the SATA driver here:
Oct 06, 2007 | Computers & Internet
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
69 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
