Question about Skagen Watches
Rubber bracelet broken
I need to replace the rubber bracelet for my Skagen Model 360LTR. Where can I get the bracelets?
Contact Skagen on line and provide the model number of the watch that should be found on the case back. They should be able to provide a replacement.
Posted on Nov 06, 2008
Where can i order "BANDING TOGETHER FOR A CURE" rubber bracelets?
Does Google not produce any hits?
Try altering search terms....
banding together for a cure
rubber bracelets
also, if you know who distributes or makes these, try searching them as well.
You may get lots of unrelated hits for all above words, so scrolling will be required.
There is a way to specify ALL words only, but I'll have to check my Google handbook.
Nov 20, 2017 | Watches
Need to purchase a replacement rubber strap for my Breil watch. The strap # is BW0379. Where may I purchase one?
visit http://www.kkhservices.co.uk/ All Breil straps are very expensive ive just found out as i need to replace my rubber strap and was quoted £57 and £150 for a metal bracelet!!!!!
Aug 31, 2011 | Briel Breil Bw0379 Mediterraneo Chrono...
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Jan 10, 2009 | Skagen 355LGSC Wrist Watch
Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
Dec 26, 2008 | Skagen Watch
Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
Dec 22, 2008 | Skagen 355LGSC Wrist Watch
Shorten band
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
Oct 24, 2008 | Skagen 107SSSBD Wrist Watch
How to adjust a Skagen Denmark Women's Steel Watch so it can fit my grandma?
good morning ! look the smooth side of pin on side part of your watch bracelet, just push it use pointed puncher pin and anvil to do that ,good luck !..
Sep 05, 2008 | Skagen Watches
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Watches Logo
169 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Skagen Watch Expert? Answer questions, earn points and help others
