Question about Compaq Computers & Internet
Not ethernet card drivers,only 8 bit color need 16 most sites do i change monitor or video card
    Genius:
  • Compaq Master
  • 1,250 Answers
Check whether the display drivers are installed or not , in device manager, if not installed , install it
Posted on Nov 04, 2008
Monitor result change 16 colors
One of your applications are changing your color scheme to 16-bit because it isn't compatible with your OS or graphics card. Try reinstalling your drivers, then disabling programs one by one when the problem occurs. For example, games that used to run on windows XP or older tended to change the color scheme and resize the monitor to 480p.
May 19, 2014 | Nvidia Computers & Internet
Monitor changed from 32 bit to 16 bit
go into video mode screen and check on your video driver for the video card.
Jan 30, 2014 | Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
My lcd colors are in a 8 bits and i cant change it i think the drivers are missing
That is the video card driver in your PC, not the monitor driver problem. You should go to the PC manufacturer or mother board maker web site to download the correct driver for your video card.
Make and model of the PC?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Mar 18, 2011 | AOC LM742 17" LCD Monitor
My monitor setting will not stay set on 32bit, it keep on going back to an low 8 bit setting that cause my colors to be off. How can I make this stay on the 32 bit. I have a Phillips 107MB 17 inch/CM2300...
The color bit depth is controlled by your PC Video card, monitor will show what it is being fed with. Please check to see if you have correct video card driver installed in your PC and the video card has enough memory to provide the 32bit color depth.
Jun 27, 2010 | Philips 107E61 17" CRT Monitor
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
My color monitor (hp pavilion mx70) is having graphics problems
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
Jun 30, 2009 | HP Pavilion MX70 17" CRT Monitor
The monitor only displays either 1920x1080 resolution with Low (8 bit) color or 800x600 with High (32 bit) color. I have uninstalled the video card and monitor drivers and reinstalled them a million...
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
Jun 07, 2009 | Computers & Internet
Thinkpad t20 problem stuk in 16 bit colors
You need a video card driver, but didn't specify which video card you have. Looks like this -might- be the right one:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4JRNJB
Jan 19, 2009 | IBM ThinkPad T20 2647 Notebook
I have lines over my monitor
Dear Mihajlo,
Your problem isnot monitor but VGA adapter, you have to install different(adequate) driver or if it isnot useful to change VGA card. Check for new driver at the VGA card manufacturer site.
Best regards.
Jan 05, 2008 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
