Question about Sony ECM-MS957 Professional Microphone
Battery corroded inside microphone
I took out my microphone after quite a while of not using it... it had been left on with the battery inside, and the battery had corroded. Now it doesn't seem to be working. Is there a way to clean the contacts so that it can work again, or do I have a (very nice) ruined microphone?
  • 24 Answers
My experience with repairing Sony microphones for a television station is that once the battery corrosion eats the copper anywhere within the mic, the circuit (not the mic) is toast. I would send it in to Sony direct as they will have the parts and expertise to turn this around quickly for you.
Posted on Oct 30, 2006
I just came across my older Sony hand held air 8 Receiver. has PSB, FM, AM, AIR. UFORTUNATELY, the batteries were left in mine. The battery case and contacts inside the radio were a little corroded. I...
You need to look at the circuit board, it is quite likely that the corrosion ate circuit paths. They are fixable but this amounts to microsurgery. If you are lucky, only the power path connecting the battery contacts is bad. Are the wires to the battery contacts intact? Use tweezers to assess this. Sadly, this damage is generally considered fatal and fixes fall into the category of personal grudge or sheer boredom.
Mar 01, 2018 | Radio Communications
Can anyone please tell me how to use a shure sm58 radio antenna wireless microphone or manual as ive just purchased this of ebay and no instructions came with it so a little lost as no sound coming from...
Shure SM58 is not a wireless microphone, so clarify me the exact model for your wireless device in order to help you.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 06, 2011 | Shure SM58 Professional Microphone
I have a Stanley tripod flash light that taked 3 AA batteries in each leg of the tri pod. On one of the legs the batteries corroded inside and I can't seem to get them out . Any suggestions to this...
After drilling each leg to remove my corroded batteries I found that each leg isa push fit allowing it to seperate from the body thus allowing a screwdriver to be pushed thru releasing the corroded batteries. Re-assemble assuring a tight fit to make connection and it works well. Good luck I was drilling 1 leg for hours and the other 2 took ten minutes.
Aug 09, 2011 | Stanley Bostitch Maxlife Mini Tripod...
5399 series cant unscrew anywhere to replace batteries very old metal version
I have the same flashlight. I had to use a vise grip and it took two of us but the bottom unscrews. Mine was due to corroded batteries inside.
Aug 06, 2011 | Coleman Graphite Flashlight
No sound from my sm58 mic
The SM58 is a very rugged and reliable microphone and there are not many things to go wrong with it.
Assuming that you have tried using a different cable / amplifier to issolat ethe problem to teh microphone itself the most likely things are.
  1. A wire has come off inside - gently unscrew the top of the mic - lift it off carefully lift because the wires inside are quite short.
  2. A broken capsule - this usually results from dropping the mic on hard surfaces. Replacement capsules can be bought quite cheaply.Just tak careful note of the wiring order before disconnecting the old one.
Feb 09, 2011 | Shure SM58 Professional Microphone
Battery terminals corroded , back up batteries leaked and corroded contacts
Go to Radioshack and buy DEOXIT.. its made to clean oxidation (corrosion) and is electronic safe. If the corrosion (oxidation) didnt leak into the circuit board this will allow you to get proper contact again
Jun 02, 2010 | Magic Sing Along Consumer Microphone
My relatively unused Shure PG 48 quit working.
You can just grab the cartridge and pull it out. The rubber bushing is just friction fit into the metal handle.
May 28, 2010 | Shure PG48 Consumer Microphone
My kodak easy share M380 digital camera froze as I was turning it
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 02, 2009 | Kodak DC280 Zoom Digital Camera
Can't not hear callers but they can hear me
yep i have the same problem too... i was gonna go to verizon today. speakerphone is not good for business calls. quite unprofessional.
Jun 10, 2008 | Samsung SCH-u740 Cellular Phone
Sony ECM-MS957 Professional Microphone Logo
246 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
