Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Tv turns on and off by itself
My TV started turning on and off by itself ( the picture works when it is on). I have tried resetting the TV and cable box by unplugging it - it seemed to work for a while last night but this morning - resetting it didnt work. Any suggestions?
    Sergeant:
  • 337 Answers
Because of the age of your set I am incline to believe you have a loose conection giving you this symptom and if I was doing the repair it will be the first thing to look for ,I am sure I would find quite a few ,resoldering them will prevent more expensive repairs and likely take care of this one.If you are familiar with tv service this will help you but if you are not seek assistance from a servicer.It should not be expensive.
Posted on Oct 03, 2006
When I turn on my tv the srceen comes on then turns black. If I turn it off and on about 4 times the picture stays on.
You have to reset everything the cable box,the TV by unplug,replug it an hour later.Let the tv reset itself back to factory setting,and the cable box to upgrade it software.If it work that great, if otherwise you need to change the cable box, I hope this will help to solve the problem....
Sep 09, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Power Light stays Yellow
sounds like you have a power issue, or maybe the power switch is faulty. check that.
Jul 17, 2008 | Vizio L32 32 in. LCD HDTV
When i turn it on the light under the screen is blue then goes orange and i have no picture/sound, kind of like when you select video and the dvd is not turned on
Tries unplug,replug the tv and cable box an hour later.The tv should now,reset itself back to the factory setting.The cable box resetting and it upgrading it softwares.The tv should work now.
Oct 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote...
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Jun 02, 2010 | Toshiba 32AV600E 32 in. TV
My TV is just over a year old and out of warranty. When i turn the TV on, I can see a backlight/glow to the screen, but there is no picture, not even the usual screensaver blue screen I usually have on...
Sound like ur Tuner board have problems or dead.Tries unplug,replug the tv an hour later let it reset itself.The tv might work again,somtimes u have to turn the off/on the power button again couples times to make the tv work.Not replaced the Tuner signal board should solved ur problems.
Apr 19, 2010 | ViewSonic N4785p 47 in. LCD TV
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Tv turns on by itself
Hey Bubba,
If your TV is turning on by itself at about the same time each day you may have a timer activated, turn it it off, the TV's micro might need too be reset. To reset unplug your TV from the a/c outlet for at least 5 minutes.
Jun 05, 2008 | RCA P52926 52" Rear Projection Television
Green Screen
my screen is green.  i can hear audio but no picture.
Jan 17, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Jan 15, 2008 | Televison & Video
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
