Question about Sony Cyber-shot DSC-S600 Digital Camera
Lens cover stuck
Ok - please talk me through getting this cover to close - PLEASE.
I borrowed the camera from a friend and don't want to return it broken
  • Anonymous Nov 28, 2008
    Having the same issue... i thought the batteries were dead and they aren't. i try and turn the camera on and i get the "cybershot" screen then shuts off. Please help
Same problem. What you can try is to clean out any dust that maybe is hiding in the lens.
Posted on Apr 15, 2012
How to fixed this problem that the lens wont closed
Posted on Dec 20, 2008
Im having the same prob with mine right now. my little sister had it for a while and she said it started doin it ramdomly but now the lens wont close at all
Posted on Nov 18, 2008
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
Sticky shutter inside the lens
Not sure that you really mean shutter, or the automatic lens cover. See the description below for a stuck shutter. If that's not what you meant, then see this instead. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 05, 2011 | Olympus Cameras
I'm unable to get the lens to go back into the
hi, Have you tried to replace with new battery your camera?I suggest use Kodak battery or check the specifiction from the battery cover and you will see the different kinds of battery you can be use to your camera.
if you already install with new battery and the lens still not moving,it means your lens was stuck up and its cause of impact or excessive force to the unit.
if your camera are still covered by warranty its better you bring to service center. but if not and you have knowledge repairing electronics. just check the lens unit and make it sure that the cable,gears are all ok and having good connection.
good luck and thank you my friend
please vote
Jul 21, 2010 | Kodak EasyShare DX4530 Digital Camera
Hi my camera will not take any photos, its just blank, however i able to still see the photo's i took before it stopped working. i borrowed it to my brother and he beleives one of his friends managed to...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Tz2 panasonic lens cover repair
I had a camera with this problem once - a friend took some photos at the beach and filled it with sand!
Try obtaining some compressed air and blasing it out.
A little WD40 (directed with care) should get that lens cover closing nicely, provided there is no debris.
Jul 08, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
Battery cover not closing
worngly he inserted take it to service centre
Jun 20, 2009 | Canon PowerShot A630 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
My camera lens is screwed up
Hey TexasStunna,
According to the manufacturer there are a few things you can try to resolve your problem, and I have provided a link below on the directions on how to do this. I hope this helps!
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00869781&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Sincerely,
Allan
Go Ahead. Use Us.
May 23, 2008 | HP Photosmart M537 Digital Camera
Zoom error
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Apr 08, 2008 | Fuji FinePix E550 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
