Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chain oiler I am not getting any oil on the chain and bar. I assume something is plugged up but I am not sure where the oil comes out and it is not even obvious how to take the saw apart. The plastic sections seem to be molded together.
  • thmpsonbn1 Feb 16, 2009
    i have a husqvarna rancher 455 and the bar doesn't get any oil i looked in the oil hole an there is a rubber plug in there is it suppose to be there
  • Curt Whitney
    Curt Whitney Apr 19, 2009
    I have Mac 3560. Oil hole and grooves are clean, but no oil comes out when engine runs. internal oiler problem.
  • 76 Answers
Take off cover to the bar, remove chain and bar. spray degreaser or hot soapy water in and around the interior housing. look carefully and you should see a small hole that is where the chain lube comes from. typically all you need is a good cleaning in this area. hope this helps.
Posted on Nov 04, 2008
Stihl 391 chain saw chain not getting oil
remove your bar and chain. check now for oil. also at this point clean and inspect the oil hole on your bar. if you get oil from unit with bar and chain off then the problem is in your bar. if still no oil and assuming you have oil in reservoir then remove clutch and oiler cover remove the worm gear and inspect. if damaged replace if not with low pressure used compressed air through to resevior
Sep 30, 2014 | Stihl Garden
The chain oiler no lnger oils the chain.
remove the chain, and the bar,, check for the little hole at the motor end of the bar, make sure its cleaned out ,, oilers very seldom go bad, they just get plugged up,
Sep 05, 2011 | Homelite Garden
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
New chain installed, cut for 1/2 hour, chain now sags well below
Place a piece of white paper on the ground
Start your saw and point the tip of the bar at the paper, this will allow you to see if it is oiling or not
I am assuming that we are dealing with a newer saw and not an old manual oiler
Blowing air back through the oil ports in to the oil tank ( with the cap removed and oil tank drained) should help clean out whatever is plugging it.
Once cleared run a bit of diesel through the oil tank, drain it and refill with clean fresh oil
I never use old oil in my saws for just this reason
Hope this helps
Scott
Mar 17, 2010 | Husqvarna Chain Saw 20" Bar
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Automatic Oiler is not working on my Husquvarna 45
This usually means the oiler hole behind the bar & chain is plugged. you need to remove the bar & chain, clean the body of the chain saw in front of the sprocket/clutch assembly. look for a small hole & clean out using something like a toothpick & wd40 or penetrating oil.
Nov 15, 2009 | Husqvarna Chain Saw 20" Bar
The chain and bar is not getting oil , what can I do to fix?
You can find an IPL (exploded parts list) with your oil system detail here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 05, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 141 will not oil and when i had it serviced they replaced the oiler and it did not solve the problem.
Remove the chain and bar assembly. Start engine--should pump oil from oiler port where the bar fits on the engine side. If oil comes out, then possibly the bar-oiling passage in the bar itself is plugged with dirt or sawdust--blow clean with compressed air. If no oil comes out from the port, check the pickup tube inside the oil tank. Drain the oil into something and fish the pickup tube end out with a hooked wire. Replace if collapsed, cracked, or loose.
Jul 04, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
365 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
