Question about Microsoft Xbox 360 Console
Error 0031 on my falcon xbox 360
What does error 0031 mean? Or likely to mean? It has been xclamped did have 0020 then 0031.
Try takin a half a turn off your screw one the cpu and gpu and see what that does. i think it has somethin to do with the heat sing bein to tight
Posted on Dec 01, 2008
  • 4 Answers
The above poster is correct. The problem occurs when the heatsink makes improper contact with the GPU or CPU. To resolve this issue I used 2 Nylon washers on each bolt topside on the motherboard.
Good luck :)
Posted on Mar 12, 2009
Three red lights on xbox360 console, power supply alright and no error messages
press controller sync and hold it and then press eject 1 light is 1 and 0 is 4 2 is 2 3is 3 most likely 0020 which is xclamp
Dec 27, 2010 | Microsoft Xbox 360 Console
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
How do you fix error 0031 on xbox 360
This error is caused by a faulty/cracked RAM brick, however it can also be caused when the heatsink is shorting out a resistor or like a bad solder joint under the GPU. If your xbox still under warranty send it back to Microsoft, if not try the xclamp fix. You could also try to Loosen your screws and make sure the heatsink isnt shorting out a resistor.You could Replace the faulty RAM brick or Cold joint/Shortcircuit under the Southbridge and/or Replace dvd power cord. Short in the dvd drive cord or the cord is in backwards.
Sep 21, 2009 | Microsoft Xbox 360 Console
Error Code 0020
First, my xbox would have one red light and E 74. Then when I opened it up and booted it I got three red lights and 0020. I took out the motherboard, replaced the heatsink compound and did the x-clamp fix, but I couldn't get nylon washers in the right size so i just used no washers at all. Varying the tightness of various x-clamp bolts gave me 0020, 0003, 0002, 0001, or it would boot up to the black screen and I'd get E 74 again. Other times the xbox would almost immediately overheat. Most of the time I would get 0020, though. At that point, I gave up and I just tightened up the bolts replacing the x-clamp a certain way (nothing seemed special about it) and put the motherboard back in the case without testing it. I screwed everything back together, and since the heads of the bolts were thicker than they should have been, the motherboard didn't really sit flat in the metal cage. But i just screwed the motherboard back into the cage not to tight with the 9 small silver screws, which I would imagine put some stress on the mobo. Then I pu the rest of the case on and the 6 long screws, and once I had snapped everything back together I tried booting it up. To my great surprise it booted up fine! I played some halo 3 and it has booted up fine every time (3 times) since then
Many people have got this error You need to replace the xclamp and make sure there's extra pressure (less than half a turn) on the front right corner of the GPU. You can read more about xclamp replacement here.
its not an issue with ur HDD so no worries....
regards iversh
a very helpful rating is appreciated for answering ur query
Sep 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 had 3ROD W/error code 0102 now its 0020
error code 0020 is a overheating error.You need to do the X-clamp fix.That should solve your problem.Did you use the Acrylic silver thermal paste?
Aug 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 0020
Basislly you keep your disc drive open for about an hour.
Then you play any game what so ever.
It will say erroe 0020 but leave it for half an hour.
Then turn it on put disc in but should work as usaul
Oct 09, 2008 | Microsoft Xbox 360 Console
3 rrod
make sure that the clamp fit on die of the processor and GPU and fist you may have an Artic silver thermal Grease i suggest, and then u titen up the srews back on it and heatup until the consoles get 2 code (overheating) and then uplug the adaptor cable and the AV cable coliitup about 20 minutes.....turn it on again and the result is......
*i have tried five times that trick and it work...
Jul 24, 2008 | Microsoft Xbox 360 Console
Xbox 360... HELP
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Make sure you remove mod before sending in as to not void warranty.
Hope this helps!
Mar 11, 2008 | Microsoft Xbox 360 Console
Error code 0020
a solution?!ok my suggest is throw away the fuckin' 360 'n buy a PS3.every time i fix that ***** another fuckin code appears.i've had 0102,0001,0020.0133!so the solution is fuckin' the fuckin' Bill Gates 'n all the microsoft./
Jan 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 0020 error code
here is a site i found that shows detailed fixes for this error with your 360's - here it is
Microsoft Xbox 360 Console Logo
4,991 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
