Question about GE Spacemaker JVM1640SJ Microwave Oven
Light under microwave
One of my lights burned out and when I tried to remove to put in new one the old one broke off. Trying to remove the bottom piece of the lightbulb damaged the holder any idea how/where to get a new one?
  • 446 Answers
I need the model number pls in order to help you
Posted on Nov 08, 2008
  • Diane painter
    Diane painter Jan 10, 2016
    Model number is LMVH1750ST
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How to fix micowave, Bottom light and fan are on all the time, no response from keys after changing PCB board ?
The door switches are ok you say...this is weird...the light will not turn off..did you take pictures of the old circuit board, and put the wires back on exactly as they came off...I always take pictures as my memory and sight are not what they use to be...let me know further..and if the new board was updated, did it come with instructions on a new wireing setup..some change the way things are wired after a new updated board has be replaced....
May 21, 2014 | Panasonic 1100w over Range Microwave Ovens...
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot tell how the 2 bulbs (surface light(s)) detach. One of them broke when I was trying to remove after it had burned out, and the glass part of the other bulb turns freely and is very loose and...
Unplug the microwave oven and get a needlenose plier and a flashlight. Wear some hand protection since you are working with broken glass.
Most of the bulbs I have seen are screw thread mounts.
For the bulb with the broken glass, use the needlenose plier and try to find the screw thread for the bulb. It should be screwed in to the lamp socket of the microwave. Carefully grab a hold of the outer edge of the bulbs screw thread and turn it counterclockwise to loosen it from the base. You may only be able to turn it a quarter turn before letting go of the bulb's thread and getting a grip on a new position to continue turning. Inch your way to remove the broken bulb's thread.
If the other bulb still lights up, I'd leave it alone.
Aug 09, 2010 | Hotpoint RVM1325BW Microwave Oven
Ge Eterna Model Em0300 HBB01 under neath light
Please unplug the oven first!
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get new bulbs in it, please let me know if you the lights are still not working. This is usually a problem on the control board that can be easily repaired.
Sep 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
125 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
