Question about Kenwood KDC-X890 CD Player
Brand New Unit Will Not Accept ANY Type of CD
Unit was installed in an '89 full size Bronco. It was brand new straight out of the box. All sources except CD work fine. When a cd is inserted it flashes "reading" once, then "loading" for about 5 seconds then ejects the cd. No other errors are displayed. I reset the unit and attempted to play a CD again with the same result. I also tried about 20 cd's on varied media, from CD-R, to store bought, new and old. I also tested the Cd's in other players and all worked fine. Is there a possibility that something is wired wrong? All speaker outputs are hooked to RCA jacks, so the only wires connected on the headunit are the keyed power, battery power, ground and remote for the amps. Is there something special you need to do to 'activate' the cd portion? The manual states the unit must be turned off from demo mode by pressing the control knob towards either AM or FM while in standby mode. When I do that, nothing happens. Does anyone have a suggestion? Thanks!
  • Loren Bachman Mar 11, 2008
    Mine had to go back. Turned out it was a defective unit. It was replaced and the new one works perfectly fine.
I am having the same problem but only with a KDC-MP335 unit. I installed it in a 1995 Jeep Grand Cherokee to the stock system, pretty easy install just matching colors for wires and everything works (Radio). but not one CD plays. it says reading and it acts as if it is playing the tracks but no sound... what is going on? did I mess up wiring it or something?
Posted on Mar 11, 2008
93 ford Bronco died while driving and now won't start
Alternator is bad.
To check:
1. Disconnect the new battery from Bronco.
2. Use another battery in place of your new battery (one that's inside).
3. If Bronco buck, then the Alternator is defective & not charging the new battery.
Check those two cables to Alternator.
Check with a DVM.
4. Or take out the new battery and have Advance Auto Part or AutoZone check for CCA rating.
atdlee@netzero.com
Nov 20, 2014 | Throttle Position Sensor Ford Bronco 96 95...
1988 ford bronco full size 4x4 installed new fly wheel and now it will not shift out of low gear
check that you have installed the gear lever in the shift rail when you refitted the lever tower on top of the box
Nov 07, 2014 | 1988 Ford Bronco
New kenmore 25,000 won't cool only fan
Sounds like bad wiring job or didn't get charged with Freon at the factory. Return for a new one.
May 06, 2014 | Kenmore 25,000 BTU Room Air Conditioner
Why is my 89 ford bronco running so rich
I saw what you replaced, didn't see any testing? Any applicable trouble codes?
Did you use a gage and check proper fuel pressure? My info on that engine size, said 35--45 psi. If the fuel pressure is too high, check the return line. As far as the fuel pressure regulator, do you have vacuum?
Jun 17, 2017 | 1989 Ford Bronco
I have a brand new straight from box LG TV model 32LD320. I have unpluged the HDMI from old TV ( where was working 100% OK) plugged into new TV. Mains switch on - and cannot get any chanels to report on...
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
Mar 13, 2011 | LG Televison & Video
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Were is the heater fan on 89 full size bronco?
should be under the glove box. take the glove box out and you should be able to get it out.
Oct 23, 2009 | 1994 Ford Bronco
Firing order for 1989 full size ford bronco 302
13726548 #1 cyl is front pass side and count to back 1234 are on pass side.5678 are on driver side.# 5 being front
Apr 22, 2009 | 1989 Ford Bronco
Kenwood KDC-X890 CD Player Logo
128 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
