Question about Epson Stylus CX4600 All-In-One InkJet Printer
Blank page I just changed brand new ink in my printer all four of them. I down load the driver from the epson's cite since i lost my driver. I am trying to print and nothing is printing. Please tell me how do i find the rite driver. Do u think the problem is with driver or printer itself.
    Master:
  • 568 Answers
I dont think there is problem with your driver cause if there was a problem with driver it wouldnt have taken the print command. just check whether u have removed the seal of the cartridges, if done so check whether the cartridges are dry or no?
Posted on Nov 08, 2008
Epson Color Stylus 880 not printing, blank pages only
With some printers they need to be the recommended brand of ink cartridge. Are you using Epson's own cartridges? If not might be worth changing to them. It sounds as though the issue is with the cartidges and not the printer itself. Hope this helps.
Oct 28, 2016 | Epson Stylus 880 InkJet Color Printer
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
Invisible printing
Lost electricity to head micropiezzo (micro pump). Usually caused by ink leakage that flow to small board at head carriage. Better take to epson service centre. If you wish to repair yourself, find similar solution on aicaxz solution.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Printer prints blank page
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printing Blank Pages!
I just got the same problem with real Epson ink. There were some solutions posted under "not printing" that you might try. I haven't yet, but I am going to reload the printer driver tonight.
Dec 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Blank pages from printer
Ahhh We love printers don't we??? Not!!! How did you clean the nozzles. Did you use the printers own maintenance system or did you do it manually. The printer can never clean them as well as you can manually, and this is probably 90% of the cause of blank pages. Clean rollers too while you are at it. Use a proper cleaning solution, and cotton buds, and clean where the cartridges go in, and the heads too. The next possibility is that the printer is set to pause, or print offline, go to your print settings, scroll down to properties and make sure thes two items are not checked. If so, unckeck them. Lastly, the drivers itself could be corrupted, and may need to download new updated drivers from epson website. Good luck
Feb 26, 2007 | Epson Stylus CX6400 All-In-One InkJet...
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
