Question about Panasonic KV S2046C Path-Through Scanner
Ready/Error Light I scan documents one day, come back the next to scan, and as soon as I try to the red light pops on, and it takes several tries to get it to reset. I unplug everything, restart the computer, etc...what should I do?
  • vickie21 Dec 20, 2007
    I have a message NO TARGET DEVICE ID: 3056. I cannot find any information about what this may mean, but I have a red light on the scanner that won't go away. I have a Panasonic KV-S2046C scanner.
  • John Dezember May 11, 2010
    The red light could be dirty sensors or just that the rollers need to be cleaned/replaced. the Panasonic User Utility wil gove a little more info about the problem: http://panasonic.co.jp/pcc/products/en/s...
4 Suggested Answers
SOURCE: Ready/Error Light
The above solution worked just perfectly..
Posted on Jun 13, 2008
  • 32 Answers
SOURCE: Red Light
This scanner has a paper detection sensor at the eject rollers where the paper comes out. Its a reflective device that can be fooled by paper dust buildup. Look in the gap where the paper is fed out, in the center you will find a little reflective patch facing up. Use a blower bulb or GENTLE puff of canned air, followed by a damp q-tip. There are similar sensors in the vertical transport that can give the same error. Don't overdo the canned air. It doesn't remove dust so much as just re-arrange it, usually to somewhere harder to reach. I don't keep it in my toolbox, and I do this for a living. Blower bulbs are much easier to control.
Posted on Apr 07, 2009
SOURCE: there is a red light error on the scanner and it
I found someone had placed a piece of tape on the cork where the scanner feeds in which was causing the sensor to believe parper was there. When I removed the tape the red light went off.
Posted on Mar 15, 2011
2001 Bonneville! Several weeks ago, had trouble turning the key in the ignition - sometimes would turn, sometimes wouldn't. Then the Service Engine Soon light came on and the car stalled out a few times...
Service Engine Soon came back on and the car is again stalling ????? Did you have it checked for DTC'S - diagnostic trouble code's ? Service engine soon light on , codes will be present !
Apr 20, 2017 | 2001 Pontiac Bonneville
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
"service engine soon" light came on while driving on interstate. had the code checked by autozone (P0455) which indicated evap problem, check fuel cap. found cap to be loose but after several days...
Usually takes quite a few starts before it will erase/reset itself, such as 50 on some vehicles. Can always return to autozone and ask to scan and erase, then see if it comes back.
Oct 20, 2010 | 2005 Nissan Pathfinder
Service Engine Soon light - 2003 Pontiac Grand Am
The loose gas cap is a quick and easy check to perform, so try that first. The service engine light will remain on until the next "cold" start.
I would also recommend visiting your local Auto Zone and ask them to scan your car for trouble codes. They offer this service free of charge, write the codes down and respond back, I can let you know what they are and mean if you decide to have a technician fix the issue.
Good luck, let me know.
Regards,
Jun 08, 2009 | 2003 Pontiac Grand Am
Dead HP 3200 series printer
The only fix I have used is a cold reset there is a firmware upgrade you can try if this does not work.
TRY THIS:
Turn the machine off and unplug for 1 minute or so.
Plug the unit back in:
Press and Hold the enter/menu key and asterisk key
Turn ON
Hold the enter/menu key and asterik key while the unit powers up. Once you see the message "Permanent Storage Initialization" let go of the keys.
Hope this helps
Apr 07, 2009 | HP LaserJet 3200 All-In-One Printer
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Orange light on LG Viewty wont go off
Try pressing the focus button several times while using camera and see if that will help, also take several pictures with auto focus and without and try recording video too, then get out of camera mode and go back to main screen, check if that made the red light go off. If this didn't help I would try a master reset on the phone .
  1. Menu
  2. Phone Settings
  3. Reset Settings
If you try this, make a back up of your contacts on your sim card, and your pictures and videos on your SD card. Hopefuly this helps, Good luck!
Dec 19, 2008 | LG KU990 Viewty
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
Panasonic KV S2046C Path-Through Scanner Logo
334 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
