Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
Release Catch Problem
We have a Kenwood Chef 701A and it has a release catch problem - it can't stay closed. Any ideas how to fix this?
  • Alex Pomar
    Alex Pomar May 11, 2010
    Hello.
    is 3 options
    1 the cric clip is gone ..
    2 the catch pin is broken
    3 quadrant assembly broken
    please check these parts ..
    Regards
    Kenwood Chef Restore
Chef 701A. Where can I get a secondhand dicer attachment?
That is really old, focus your search in the UK and auction sites selling second hand stuff.
Jul 15, 2015 | Kenwood Food Mixers
When using my Kenwood Chef A901D the machine does not stay down in a locked position but pops up. Is this a spring that needs replacing or can you diagnos the problem for me. Thx
Late but I had the same problem and fixed it on me tod so maybe it will help someone else. There are two stages of closing, it will shut at around 6 o clock but it's locked when it's around 8 o clock (it should click into this same position when fully open) I fixed mine by pushing it down harder than I was doing. If it won't lock after this then a spring is borked.
Apr 15, 2011 | Kenwood Food Mixers
Cant releace the dough hook from my kenwood chef. what can i do?
hi the lock nut on the shaft may have been loose allowing the shaft to screw into the dough hook you hve to unscrew the hook out of the shaft then unwind the nut down so you can release the shaft. other problems can occur if the retaining clip has unseated and jammed itself into the planet hub. this is more difficult and a kenwood agent would be consulted see www.kenwood.co.uk for nearest agent.
Feb 09, 2011 | Kenwood KM300 Chef Stand Mixer
I have inherited an old Kenwood Chef mixer...I am unsure of the model but it is probably 30 years old, is white and the cover for the blender is blue. It was made in Australia, Elizabeth SA. I have...
Can't refer you to a dealer there but it is likely that only the motor's brushes need to be replaced. This isn't a difficult DIY job and the brushes shouldn't cost more than ~ $20 US.
You could also remove the housing covering the motor and see if the commutator is visible. This is a segmented copper cylinder and shouldn't be completely blackened although some signs of black is normal. The brushes ride on this cylinder and if the brushes have become too short, it can cause arcing and smoke. Clean that surface before installing new brushes and they too may smoke and cause rough running until they are worn in. The brushes can be had many places so you will have to choose one convenient to you:
Kenwood Chef Brushes
Jan 20, 2011 | Kenwood KM305 Stand Mixer
Kenwood Chef not working
I got service manual if any one want it.seamusria-at hotmail.com for kenwood Kenwood chef model A.701A.
Jan 11, 2010 | Kenwood Food Mixers
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Jun 05, 2009 | Kenwood KM300 Chef Stand Mixer
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef model 781a
To open take off the top and open the three screws. Use light grease.
Jul 01, 2007 | Kenwood KM800 Major Classic Stand Mixer
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
