Question about Teac PD-H500 CD Player
Teac CD Changer (7 disc)
My CD changer displays "disc error" and shows there is a disc in slot 1. Although I thought we removed all the discs. The door does not open (w/the open/close button). Not sure how to go about it fixing this. Can we somehow open the door another way? Thanks
4 Suggested Answers
SOURCE:
robotek
  • 1512 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Posted on Jul 07, 2008
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
SOURCE: Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Posted on Aug 11, 2011
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
Mar 23, 2014 | Technics Audio Players & Recorders
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
Panasonic 6 disc changer has suddenly stopped playing CD's and now shows E-1, E-2 and so on, messages while trying each disc sequentially, in my Opel Astra. I have tried the reset button to no ava
A CD may have gotten stuck moving from its slot to the play mechanism or while returning to its slot. If repeatedly pushing the reset button does not restore operation or make it possible to pop out the magazine, you may be in for a difficult task of removing the magazine manually but the stuck disc has to get unstuck first
Sep 25, 2012 | Car Audio & Video
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Getting ERR message on CD Player
My kids always cause this one ! Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminium cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should thne be ok. If it has been forced, the aluminium cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Jan 14, 2008 | Teac PD-H570 7-Disc CD Changer
Keeps displaying error cdc
you can try to use a cd lens cleaner CD. Put the lens cleaner in slot 1 and load disk 1 the cleaner shouls be dropped in place and begin to clean the cdrom lens.
Sep 18, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Teac PD-H500 CD Player Logo
57 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
