Question about Xerox Phaser 8200 Laser Printer
Error 15.004.45 Phaser 8200
You provided excellent information on the fix for another user. You suggested contacting you if they were going to fix it themselves. I intend to pop out to buy the bulbs today at Lowes or Home Depot. I would like to get the detailed steps to do the "time consuming" replacement.
Thank you, in advance.
rafiki
    President:
  • 2,072 Answers
First of all you will need Torx bits or drivers to remove the covers etc. I think mostly you will need a number 10 and 15 size.
First off you want to remove both side covers, there is one screw on the top back of the covers, and another on both covers, top front, you have to open the front paper path door to access the front screws. Then about the middle of the covers pull up and outward, they will kind of pop off, but thats fine, they have tabs on the bottom that can be pesky.
Remove the paper tray, the green maintenance tray and set aside.
Now remove the 2 green rails that the maintenance kit rides on. They both are held in by one screw. It will take some manupilating to get them out, but basically you push them sliightly back, inward and twist slightly until they come out. TAKE NOTE of how the leaf springs are on the rails, A hint when putting them back in, is to take some scotch tape and tape them on the side to keep them in place, You will see what I mean when you remove them. But its much easier to get the rails back in when those springs are taped to the side. And no worry about removing the tape afterward, I will have no affect on the machine if its left in.
Next, you look up and you will see a stainless steel curved plate. About 10 inches long and 3 inches high. There are 2 screws on the top of it that must be removed. There are 2 tabs on bottom, Once the screws are removed it just lifts out.
Now about midway up the paper path is the registration rollers. First, you have to go, ( looking from the front of the machine) to the left side of the machine, You will see a electromech clutch on a shaft with a 2 inch black gear with a belt attached. Remove the clip that holds the clutch on, slide off the gear and just let the belt drop in place.
Now, return to the front,The assembly is stainless steel, you will see a couple of rollers on it and some paper path actuators. There is one screw on the right side of that assembly that you need to remove, and on the left side, just by the bearing there is an "E" clip holding the bearing against the frame. remove the screw and the clip, Then move that transport CAREFULLY to the left and out. Be very careful to keep the 2 pieces together, there is a switch actuator that can be easily broken. So please take caution. On the right side, there will be a bearing that WILL fall out, and drop down into the paper feed area. Trust me it will do that. Just locate it and pick it up. When replacing that transport. I suggest, ( unless your considering suicide LOL) Put some white out or a little glue on the outside of that bearing when you press it back into the frame. Otherwise, IT WILL keep falling out and really try your patience. Just trust me on that one.
Now, look in the front , just above where the maintenance tray would go. You will see 2 screws, about 10 inches apart, They will be surounded by a beige/brownish plastic. Remove those 2 screws, they hold in the heater assembly you want to repair. When you remove those screws it will not yet come out, wiggle it a bit and look on the right side so you can easily determine the conectors, plugs you need to remove. Some have 1 some have 2.
Once you do that, slide that heater assembly downward and out. You will see the 2 lamps in there.
Take those little spring metal clips out,, replace BOTH lamps. Use some emery cloth to clean the contacts. Clean the reflector behind those lamps before replacing . That will make the heat transfer more efficient.
Once those are in , in reverse order reassamble. Just be cautious replacing that registration assembly so you dont break the black actuator.
It's really not hard, just takes some time. Give yourself an hour to an hour and a half. But that is your problem I guarantee it.
Posted on Nov 06, 2008
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error xerox Phaser 8200 15004,45:12318
Hi erniec420:
Hope that this helps.
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Apr 03, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error code 15.004.45.172027 on Phaser 8200
I would suggest calling a service agent and have him bring a paper pre heater.
Feb 25, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
