Question about Toshiba 57H81 57" Rear Projection Television
Horizontal sync When I first turn the TV on it has no horizontal sync. As it warms up the picture becomes clearer. It never really comes in clear and seems to be getting worse. I can adjust convergence but it does not fix it. The HDTV inputs seem fine, no sync problem. Could this be the tuner board ?
    Problem Solver:
Zeutaluras, My guess would be the same as yours because the horizontal osc. is synchronized when you apply the signal to the HD inputs. I am assuming the signal with embedded horizontal sync and composite video passes through the tuner boards as you mentioned. I'll confirm with the schematic once I see it. If it is a separate board can you get one to substitute? I think you may be able to locate the problem with an oscilloscope and schematic if you can access different points in the schematic. I'll try to help once I know more. My problem prevents any type of built in diagnostics since the set doesn't power up.
Posted on Oct 04, 2006
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | RCA F25432 25" TV
Horizontal squiggly lines blurring the picture
If its a Toshiba some years old it is the Hyper board bad---a brand and model number are not indicated on this question.
Nov 03, 2012 | Televison & Video
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
Picture will not come on but flashes sequence of 6. I can hear it when I turn it on. I've unpluged it trying to reset it but to no avail. What can be the problem and what would the estimate be to fix?
hi,
first check is there is any dry soldering on the circuit board. by 6 blinks its means its horizontal side is not working. may be because of problem with the main chroma ic( its a jungle of horizontal, vertical,sync, and colour.). also check the horizontal driver transistor and transformer.
also check one more thing the horizontal power supply voltage. check the protection zenar in its rail.
ok
Dec 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Toshiba 57H81 57" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
