Question about Radio Shack Pro-2096 Base Scanner
Blank screen goes in and out
My screen sometimes fades out then comes back in whenever it feels like it
  • dcpete May 08, 2009
    I removed the ribbon & trimmed it ,cleaned and reattached it. no good. Bought it brand new in the box from RS for 160.00,last one they had.Im going to take it back. Is a good scanner out there?
    My pro 96 lasted 3 years no problems and now the antenna broke from within the unit? I dont know how to fix that.
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Posted on Nov 29, 2008
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
My LG 2353 monitor screen goes blank by itself. Sometimes it will go into sleep mode or sometimes my screen just blanks out and the power light stays solid red without flickering to indicate whether or not...
shaylane_195, Good description of problem! But you left out one or two key things to tell me. Age of monitor? Approximate total "ON" hours of use? Is unit covered by LG (Lucky Goldstar) warranty? You and only you can tell me if the screen is really BLANK, or is it only BLACK? Do flashlight test to determine true state of screen! Can you see very, very faint image of WIN-desktop holding bright flashlight near your black screen? This monitor works!!! You just need to fix the possible (1) "cold, frosty looking, thermally intermittant solder connection on the "internal switch-mode-power-supply/CCFL inverter board. Yes, your monitor along with many other CCFL back-lit LCD units of all brands also could have some BAD, swollen, leaky electrolytic filter capacitors installed on the SMPS/CCFL inverter board which will need to be replaced with new ones of higher quality. Get back to me, lmistyrel on aim. or do additional comment on fixya, after you do some reading in my and other fixya tech's profiles to discover all options you as consumer/user have open to you. Bye for now. 12fixlouie
Mar 04, 2010 | LG W2353V-PF 23' LCD Monitor
My ln-t4042h turns on and stays on for a while and then the screen goes blank then coming back on and off then stays blank. Also while it is actually working you can see the brightness fading in and out.
U have sound,after picture fated?Ur LCD inverter board it dead.must replaced this board to get the picture back.It usally a long board.Tries, for the board part.
Feb 06, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Sidekick lx screen went blank isnt working..
You can try to reseat the lcd cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
Oct 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I sometimes get a blank screen while i'm using the computer or when i'm watching a dvd? why is the problem?
you may have screen saver active with no background selected, so when it goes to screen saver it only show blank scree. next time screen goes blank touch a key, if screen comes back, it is your screen saver, go to control panel find personalize and go to screen saver, make changes.
Aug 19, 2009 | Acer Computers & Internet
Lg rumor phone screen goes blank! Then comes back on its own.
its broke...ive had many rumors finaly sprint saw that it wasnt me breaking them and i upgraded to a pink instinct for a good price...i would say try and get a better phone because trust me every rumor you get will end up breaking the same way!!
May 22, 2009 | LG RUMOR Cellular Phone
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Screen fades out whenever i choose a song
Software corrupt. Try finding out how to install it again or update firmware. If you cant, get another brand. THey like cheap, stop trying to ressurect the dead
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
SMT 5600 does not load OS, screen goes white and then blank.
Screen sound bad, or intermittent connection inside. You can find disassembly instructions on the net. Search with phone model and disassemble. Remove and reattach all cables in case one is lose or contact dirty.
Dec 17, 2007 | Audiovox SMT5600 Smartphone
Radio Shack Pro-2096 Base Scanner Logo
341 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
