Canon PIXMA MX700 All-In-One InkJet Printer
Problem for Canon PIXMA MX700 All-In-One InkJet Printer
5100 error
By ratab on Nov 04, 2008
I have cleaned the printer, and no paper is jammed. I have turned it off and on, as this worked in other occasions, but not now. The 5100 error comes up in the LCD screen when there is a power failure and then the electricity comes back, it would seem like it is disconfigured by that. The last time I turned it off, unplugged it and unplugged the usb plug to computer, and then replugged everything and it worked. Not any more. Thanks for your help.
Comments:
Nov 26, 2008
- NOthing worked, I have tried all solutions and the error persists. I went to the dealer to consult and he said it is usually with these printers the voltage differences so he recommended I purchase a ups with battery charge to avoid this recurrent problem each time we have a power failure.
Same Problem
Nov 30, 2008
-   I have the same problem and got it fixed by trying some maintenance tests, it then printed one page only and then immediately when i sent another page i got the same error. No solutions posted help? Any other suggestions, it is pretty new printer! -   derekborror
Solution #1
posted on Nov 04, 2008
Somewhat Helpful)
Ajkill
Rank: Wiz  Canon Expert
Rating: 84%, 1125 votes
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
if this did not check if the cartridges is fitted in place ,even this did not clear the error then
Turn the printer off.
. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
and then power it on and check ..if this fails it must be serviced ...
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX700 All-In-One
Do you recommend Canon PIXMA MX700 All-In-One InkJet Printer?
Answer
Answer
Getting Error code 6A80 trying to print labels from MS Access
Answer
After trying to run perferated card stock the printer never loaded if form the back and then... (More)
Answer
I get an error code 5100. Printer does not start to print. I have checked the printer head and... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , PA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
