Question about Microsoft Windows XP Professional
Windows xp not recognising any hardware e.g.Pendrive,bluetooth
I have two OS installed on my computer Xp and Vista Ultimate
Everything is working fine but when i connect anything to usb ports in windows xp nothing happens.
  • 1 more comment
  • Pritish Singh Nov 05, 2008
    its dual boot.
    not even a single usb device working in xp.
  • A Mayers May 11, 2010
    Did you install with dual boot or is one a virtualized install?
  • 4 Answers
Check are your usb driver is properly installed or they are enabled... I happed with me also... It took some time to locate and install the usb by windows but it can also be the cable problem... Check these things and if nothing is wrong within these then try to reinstall the windows and i am sure that this will solve your problem!
Posted on Nov 05, 2008
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Problem loading OS on Gateway MT6451, Main File Error
This looks like a corrupted file in the boot section or a virus attack. the only solution is to reinstall the OS. there is no hardware error, if you had any hardware error the display will not be working fine. reinstall the Windows OS.
Please encourage us if this tip was helpful to you.
Apr 02, 2010 | Gateway MT6451 Notebook
My vista laptop will not allow me to play a game as I do not have the latest OS????
Ah - its not Vista at fault here but the game - it does not recognise Vista properly. Re-install the game by righ clicking on the installer and choosing Troubleshoot Compatibility - then trouble shoot - say it worked on previous version of Windows
Vista will then Emulate XP and it should then work fine.
If this helped please vote kindly
Oct 07, 2009 | Microsoft Windows Vista Ultimate Edition
Driver instalation doesn't work in Windows Vista Ultimate
Make sure the drivers you have are compatible with Windows Vista. Since Microsoft ceased any and all support for that Windows OS it's hard to find anything for Vista or XP. Type in your webcam maker's name and camera model number followed by: 'drivers for Vista' into your favorite search engine box.
Sep 18, 2017 | HP RD345AA Web Cam
It is possible to downgrade my OS vista to XP
First and foremost before you do, you need to check to see if drivers are available for your computer for windows xp. Or, if you are more adventurous, find the .inf files that go with your current drivers, find the hardware ID"s in them and then install drivers either directly from manufacturer of component, or download XP drivers from other models with same hardware ID's. It is possible, just make sure you do your research for the drivers first.
A quick search indicates that it has been done, but the HD audio is a bit tricky. Good luck!
Oh, and one more thing, please take a moment to rate this solution with a fixya rating. Thanks! :c)
Jan 26, 2009 | Microsoft Windows Vista Ultimate Edition
Upgrading the OS Windows XP not possible
Upgrading from OS Windows XP:
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
NOTE:
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
 i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Vist Home & Proffessional
partition your hard drive thats how you can run 2 operating systems on your computer im running xp pro and vista ultimate
i recomend you use vista ultimate it has it all
Jan 03, 2008 | Microsoft Windows 98 for PC
Install window xp over vista ultimate
CHECK WITH YOUR SYSTEM MANUFACTURER WHETHER OR NOT YOUR WARRANTY IS VOIDED IF YOU INSTALL AND DUAL BOOT WITH WINDOWS XP. MANY OF THE NEWER SYSTEMS ARE DESIGNED AND CONFIGURED TO ONLY RUN WINDOWS VISTA. HARDWARE ON YOUR SYSTEM MAY NOT BE DESIGNED TO RUN WINDOWS XP.
Here is how:
http://www.pronetworks.org/forum/about88231.html
Jan 01, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
