Question about Quasar TP-2009D 20" TV
1992 Quasar model TP1310FE too hot
TV is unusually hot, even when turned off?
Remote control from Dish tv will not work volume on Coby 32" flat screen
This is not unusual--Dish and other remotes even if program will not have all the functions that may be needed---
Dec 03, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Hi MY TV HAS NO PICTURE OR SOUND, AND IT WAS FLASHING RED WHEN TURNED ON, BUT NOW IT WILLNOT EVEN GO ON AND I COULD NOT HEAR THE FANS ON EITHER, PLEASE HELP
Follow the money or this case the voltage--follow power cord into the set and to the power supply board--there will be a fuse there---extremely unusual for there not to be blinking lights if the set does not turn on---
May 28, 2012 | Sony KDS-60A2000 60" HDTV
XTANT AMPLIFIER GETS UNUSUALLY HOT WITH MINIMAL LOAD.
Check your ground wire. If its loose or bad. It will cause your amp to run hot, and can damage it
Nov 10, 2011 | Car Audio & Video
Starts geat, runs good, but after driving 20 minutes and shut it off, wont turn over, like battery is dead, Battery posts unusually hot. all new parts.
Based on the information provided, it sounds like a bad starter. Even a bad starter when cold will start your car or truck. When a bad starter heats up, it requites more and more power to make it engage. If you've ruled out other possibilities, I'd consider replacing the starter.
Jun 16, 2011 | 1985 Ford F 250
I have a 56 inch rca rear projection tv and after two hours starts turning of and on for about half hour and then turns off. when we turn it back on it shuts off and comes on fast and then shuts off....
Those type of tv sets get unusually hot at times. Could be a heat issue. Power flow at night is the best. If it's still turning off then, it must be a dust or heat issue.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
No buttons work on the tv or the remote except for the power button on the tv
This appears to be a unusual problem but it is not.
If you had a power outage even if the set was not on at the time it can affect the set. The set has a microprocessor that looks at things every time the set is turned on or off.
Even a brief interruption in power can "confuse" the set.
With set turned off, UNPLUG TV FOR AT LEAST TEN MINUTES and then plug back in and see if all returns to NORMAL.
I would hope it does as the other possible cause is something serious is wrong with the microprocessor circuitry in the set.
Let me know if it fixes the problem or not.
SD TECH
May 14, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Heater/AC Fan Problem
sounds like a shorrt to 12v to me. The wire is hot and the fan is shutting off because the blower is bad, getting to hot, it will bind, causing over amperage.
Feb 03, 2010 | 1998 Toyota Camry
Vacuum was running unusually hot recently and then
if it was running hot somethinghas melted together and now wont start must be torn apart to see what has failed most likely the vac motor impellar.
Jan 27, 2010 | Vacuums
Does not come on. there is power to it but it does not com on. every once in a while it seems to be trying. like a surge but then notheing.
the tv is more than likely full of bad current and needs to be discharged. unplug it for about 24 hours, and then plug it back up and try it again......about 12 hours into the unit being unplugged, hold the power button down randomly for about 30 seconds at a time........plug the unit back up, try to turn it on, and listen for any unusual noises.....if you can, try to smell....yes smell.....the vents on the to back side of the tv, to see if anything smells like it is hot, or "frying"....everyone knows the smells of something electrical that is hot, and if you dont, you'll know it when you smell it.
if you encounter any of these issues, the nunplug the tv and dont try it anymore. you're last options would be a warranty exchange through the manufacturer, or taking it to a tv repair shop, or simply buying another tv. it's just limited on what you can do, as far as repairing the unit yourself goes, as there are several part of the tv that can hold enough current for up to 6 months, that WILL kill you, if you even so much as touch them. obviously i do NOT recommend trying to take the unit apart.
Oct 03, 2009 | Sony FD Trinitron WEGA KV-32FS210 32" TV
Philips 32PW9536 TV, bought in 2002. Screen has been losing resolution gradually for a while, and now onscreen text (PS3, Wii, Satellite TV, even the TV's own menus) is almost unreadable. Occasionally it...
This is very likely the tube is starting to show signs of age, If you turn up your contrast or brightness level does it make the picture look smeary? Your description of the menus does suggest strongly that the tube is the problem & seven years old this is not un-common.
Jul 15, 2009 | Philips Televison & Video
Televison & Video Logo
49 people viewed this question
Top Quasar Televison & Video Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
