Question about Bosch Dishwashers
Food particles on clean dishes each time - Bosch Dishwashers
    Sergeant:
    Champion:
  • 324 Answers
Check you pump/remove screen at the bottom of the tank and check for food blocking water flow.
Posted on Nov 04, 2008
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Most likely causes are:
Hope this help. Good luck.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher throws food
check for filter on botton around pump and clean it
Feb 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Dishwashers Logo
123 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
