Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
Motherboard start problem
When i start machine first time in a day it`s start properly ,and i restart the machine many time it`s work`s properly. but if i shutdown this machine it`s not boot or not start. when i start next day it`s again startproperly.and the problem still to be continuious. i tride to resolve the problem. i removed the cmos battry & ram full hole day & night.
  • manish bisht Oct 04, 2006
    but this cpu fan is always moveing.no beep,this m/b is hp branded machine.i changed the hdd and ram.
Surely it is a virus attack, u save ur data and reinstall the windows xp(any version) u r using...
Posted on Apr 18, 2008
I think youreplace the Ram with new one it might soule the prblem
Posted on May 29, 2007
When i restart my computer it shows cmos time is not set and cmos battery failure then after this mes i changed the battery and set the cmos time correct. it works properly till one day and another day it...
I had the same problem one week ago. Check if your SMPS power connection is OK. If it's OK, then you may have to change your motherboard... I mean may be your motherboard is corrupted. Open your cabinet, unplug all the components and clean the whole cabinet properly and re-assemble all the components. Restart your computer but still if the problem sticks be sure to check your computer with a well-knowledged hardware mechanic because there may be other causes.
Dec 22, 2010 | Computers & Internet
Machine powers itself off and then eventually restarts
it must be due to ur pc's on/off switch faulty.... try to change the switch. or open the cover of ur cpu and change the on/off switch cables with restart cable. i.e. swap the cables of on/off and restart (remove the on/off cable don't fix it when checking)
Jun 25, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Clear pasword and boot block recovery problem
At the bottom of your motherboard there should be a 4 pin stand with a jumper on only two of the pins.Move the jumper to the remaining two pins and reboot.
Oct 11, 2009 | Intel Motherboard
C:\progra~\mywebs~1\bar\1.bin\m3plugin.dll
Go to regedit (click start then search and enter it there) and do a search for M3PLUGIN.DLL when found delete that registry, then restart your machine. Its missing or damaged and thus unnescessary, no worries whatsoever. have a nice day!
Aug 18, 2009 | Intel Motherboard
No sound output
I think ur sound driver is not properly installed . Plz first uninstall the driver and again reinstall driver .
Note :- Whenever u uninstall and install some programme after doing that operation plz restart the machine . After restarting the machine the software will be properly uninstall or install .
May 26, 2009 | MSI MS-6734-10 (-6734-010) Motherboard
Dell 8400 is not starting
Check if the RAM is seated properly and clean too. Check your power supply(SMPS) for the 3 voltages it should generate. RAM will not need any replacement however your SMPS may require replacement...sodeep
May 12, 2009 | Dell Dimension 8400 PC Desktop
KEYBORD PS/2 PORT NOT WORKING
Please check the Fixya repair directory for a list of people who will repair your keyboard port near you.
Mar 02, 2009 | Computers & Internet
Problem in DG31PR
ok
when upower up the computer press "del" or F2 or F3 to enter i n bios settings then go to exit menu u see load optimal defaults settigns give enter on it then save and exit.
Feb 07, 2009 | Intel DG31PR Motherboard
My p5vdc-mx motherboard will not power up, it used to work in its old dektop case, then powerd its self down one day, so i bought another desktop case placed the motherboard in side all neet and tidy, it...
check the memory not playing up by changing them or taking one out if you have two, this can cause a shut down, and stop it restarting, unplug all hardware you dont need and try starting use the eleimination process, until you get a restart. cheers Peter
Dec 14, 2008 | ASUS P5VDC-MX Motherboard
Computer not started properly
the window is corrupt try to repair the window with window xp
May 30, 2008 | Intel D845GVSR Motherboard
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
104 people viewed this question
Top Zerus Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
