Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore refrigerator not cooling and lights out
My Kenmore rerfigerator decided to stop working this morning.
The fan is on but not cooling and the interior lights are all off.
It is a kenmore side by side about 8 years old. Can't find the model number.
Can anyone help me with this?
    Champion:
  • 210 Answers
Is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Posted on Nov 05, 2008
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Kenmore refrigerator freezer stopped freezing and cooling then several hours later started working again ?
Look at what time the defrost timer is set to. It may just be as simple as resetting the time or you may need to replace it .
Aug 04, 2014 | Refrigerators
Middle part between doors are extremely hot on my Kenmore coldspot side by side
TAKE THE BACK COVER OFF THE REFRIGERATOR. SET UP A COOLING FAN TO COOL COMPRESSOR. YOUR CONDENSOR FAN MOTOR HAS STOPPED WORKING.
Apr 24, 2010 | Kenmore 57029 Side by Side Refrigerator
Moved working Kenmore refrigerator now it does not cool,
moved refridgerator now not working only light on??
Oct 07, 2009 | Kenmore Refrigerators
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Side by side refrigerator and freezer not working, (fan not working either)
This doesn't sound good does it?
The good news is that the compressor at the back, is probably fine, it's just waiting for the signal to turn on.
First, try adjusting the controls from minimum to maximum to see if you can get any life out of it.
If you have no power to the display, please state this.
If it does function - but not properly, please state this.
If there is no action at all, I suspect there is a fault on the main control board, or the motor run capacitor is faulty. With a faulty capacitor, you may get a 'click' when first turned on, and the compressor will buzz or get warm without actually cooling.
Hopefuly this will help, but please get back with more information.
Thank you.
Oct 14, 2008 | Kenmore 57029 Side by Side Refrigerator
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
224 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
