Hi, I just received some LS3008 which I have to set up in a factory. The problem is: they are using Windows 7 (English US version) with a french keyboard. I tried to use the given barcodes to set up the devices with no success...I assume they have been done for an other windows version....If you know what is the problem, could you please let me know what's going on ? Thank you for your help. Regards. Bertrand
SOURCE: setup issue
you need to use a code book to program the gun how to behave (and by what kind of interface it is using) I found this note please look http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=ADC-00084&sliceId=SAL_Public&dialogID=26700221&stateId=1%200%2026686911 you should have a book of barcodes to customise the configuration of gun to behave how you want it to. here is the electronic version http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf&sliceId=&dialogID=26700221&stateId=1%200%2026686932
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
SOURCE: ENTER after reading a barcode
look on page 200 (5-150) and scan the barcode there, then scan a four digit barcode you print based on the code in the appendix. I see 7013 on page 243 as the Enter key. also look at the code on 203 for the <data><suffix> format.
I would do these steps....
1. scan the code on page 200
2. scan the barcode you create of 7013
4. scan the code on page 201
5. scan the code on page 203
6. scan the code on page 206
Does that help?
SOURCE: Barcode reader language
Concerning the Z issue you should select german keyboard from 123scan
Else you will have to program macro to substitute the caracters
SOURCE: LS4278 scanner can't read digits
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
