Question about Acer Computers & Internet
Built in speakers
How do you get them to work?
Should I have installed software or is it as simple as plugging in a device (MP3) headphone ut-monitor in?
  • Niqueaf Nov 07, 2008
    Seems a coworker had thrown the disc away, luckily we had one more new monitor still in a box with what we needed.
  • 749 Answers
Just plug it in! if your monitor comes with an installation CD then install the drivers needed.
Posted on Nov 04, 2008
Can't get the built in webcam to work on my computer
well....the Webcam has it's own connection to the PC, (typically a USB cable,) but the sound will come out of your speakers.....so if you have your speakers built into your monitor, then yes, there needs to be a 2nd cable from the monitor to the back of the PC. It should have a headphone jack at each end; there will be only one place on the monitor it will fit. On the back of the PC, there should be a small round pale-green connection to plug-in near the USB ports, (unless you have added your own separate sound card, then it should go there.)
If the video is not working, then check if it is plugged into the EXACT same USB port. You do not note what OS you're using....but usually I recommend a device be removed from the device manager, then rebooted several times before attempting to re-install it.
Aug 29, 2012 | Dell Inspiron 537 ST PC Desktop
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I cannot get sound from my internal speakers on dell d600 latitude. Headphones work and sound comes out of internal speakers briefly when pulling jack plug out? So I know they work but just cannot get...
This sounds like a defective audio port. In normal operation, plugging in a headphone plug breaks the connection to the speakers. On your laptop, when you pull out the plug it makes a connection, but only briefly. Unfortunately the audio port is built into the system board. I don't think you will find a software fix for this problem. Your best bet is to get a USB sound device for external speakers.
Apr 27, 2010 | Dell Latitude D600 Notebook
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
Aug 26, 2009 | Emerson Audio Players & Recorders
Speakers or not
If your monitor has speakers built in, it's likely that there is an Audio Out port on the back or one of the sides. You can use a simple 1/8" input/output cable that will connect to the port on your monitor and the Audio In port on your desktop.
If you already have that set up correctly and you are still not hearing any audio coming from the monitor, there may be a configuration console that is available after installing the software for the monitor. If you don't see any software installed, find the installation disc and see if there is an application available to install.
If you don't have the disc, you might be able to find the software online at the manufacturer's support site.
You might also be able to change some configuration settings from within the Sounds and Audio Devices console in Control Panel.
Hope this helps! Good luck!
Aug 09, 2009 | AOC 718Swag-1 LCD Monitor
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Trying to add speakers
The only way i can see of feeding two sets of speakers from the one pc would be to buy or make up a "splitter" audio lead .....i.e a 3.5mm stereo jack on one end connected to the pc with two lots of wiring going to 2 3.5 mm jacks. I don't know whether a store like Maplins would sell such a lead. Are you any good with a soldering iron??
Dec 31, 2008 | Gateway GT5468 Desktop PC
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
Speaker and headphones
Go to the settings menu and change the audio output to headphone only.
Jan 27, 2008 | iLO (2 GB) MP3 Player
Computers & Internet Logo
385 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
