Cannot install omnipage se. wizard interupts process
  • Anonymous Dec 04, 2008
    I cannot uninstall Omnipage SE - neither via Windows (Vista) remove software, nor with the remover tool that Scansoft provides... It seems to interfere with Internet Explorer, so I would really like to get rid of it!
  • maggiebee48 Jan 03, 2009
    I have the same problem. It tells me I need 'permission' to do this. I keep getting annoying pop ups at start up from this software, asking me to register it. Could this be the problem, or would registering it make the problem worse?
    Maggie
    Problem Solver:
  • 6 Answers
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Posted on Oct 22, 2010
My Canoscan 4200F has no OCR software. How do I get it?
OCR software is usually a third-party program. Sometimes it is available on the original driver CD but it isn't included in the downloaded driver software. In the case of the CanoScan 4200F, the CD included the OmniPage SE OCR program. The SE indicates a Special Edition only bundled with the scanner and was only available for the OS versions that had been released when the scanner was first available. If you have the original CD (for Win98-XP), try to install the program using the Custom install option. (Check your current OS version. A 32-bit OS is more likely to support the OmniPage SE. With Windows Vista and 7, click Start > Control Panel > System and Security > System to determine the version. x64 indicates a 64-bit OS. ) If your current computer doesn't have an optical drive, use an external optical drive to install the program.
If you do not have the CD or your OS is incompatible with the Omnipage version on the CD, you will need to either purchase OmnuPage ($99 with a rebate from many vendors), AbbySoft's OCR program or one of the other OCR programs. SimpleOCR is free for personal use, http://www.simpleocr.com/Info.asp . The biggest problem with the free OCR programs is that they do not handle documents with columns properly.
I wish that I had better news for you.
May 31, 2012 | Canon CanoScan 4200F Flatbed Scanner
Cannot install Omnipage 18
get the old program that you have installed and click on it to get up the properties tab
click on compatibility tab
click in square and then high light win 7 click apply and ok
the fault is that you are getting the error message as you have a program already installed and if you want to install a later version of the program you will first have to go to programs and features in the control panel and uninstall omnipage program and all programs associated with the omnipage name
Jun 24, 2017 | Office Equipment & Supplies
OmniPage Professional 16 fails to launch
uninstall the program, reboot and then reinstall it following the instructions and on-scree commands and prompts. if the result is the same, maybe consider changing the version of your os, maybe your os somewhat conflicts with the program. try using oem os'
Jun 02, 2010 | ScanSoft Nuance OmniPage 16 Professional...
How do I uninstall omnipage se from my laptop? I have tried going to the control panel and clicking on ''add/remove programs'' and when I click on remove program it starts to uninstall then a window comes...
Use Revo Uninstaller. It will work like the Add/remove programs however it will forcefully remove the programs and also will let you remove its registry items of the Omnipage.
May 17, 2010 | HP Pavilion dv2000t Notebook
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cannot install omnipage se. wizard interupts process I cannot uninstall Omnipage SE. It interfere with my Internet Explorer also and I can't find anything that works to get rid of it.
Try this link - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=13371#DownloadDetailAct
If helped rate fixya
May 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
In trying to install OmniPage SE onto a new computer with the vista operating system, all goes well until I come to the installation of OmniScan SE. I get the message: "The wizard was interrupted before...
Unfortunately, Nuance most likely doesn't have a Vista patch to sort the problem with Omniscan.
The best advice I can give you is to remove Windows Vista from your system and install Windows XP.
Vista is riddled with bugs and incompatibilities with many software packages and has been replaced with Windows 7 which is due to be released soon.
Rather use windows XP until Windows 7 becomes available and save yourself many further headaches.
Let me know if you would like any further assistance.
Best regards,
Graemevm
Apr 28, 2009 | Canon ScanFile OCR Full Version for PC
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
How to scan using canon pixma mp150
I hoe it helps!!!
945 people viewed this question
k24674
jasbo
jasbo
