Question about Xerox Phaser 8200 Laser Printer
Fault 15.004.45:6917 I keep getting this Printer Error
  • Rafiki Ali Nov 19, 2008
    Thanks, got both replaced and now the paper jams and i get the recurring error: 07.003.45 ... any thoughts?
    President:
  • 2,072 Answers
There are 2 -150 watt halogen lamps in the machine that heat the drum. One or both are blown out.
Turn the lights off in the room with the printer then turn the printer on. Look on the right side cover, you will see an exaust fan vent, look in there and after a minute or 2 see if you see lamps gloging inside the machine,( I seriously doubt you will). If not, those are bad. They are not real hard to replace, just take some time and patience to do.
Let me know if you want to try it.
They should cost less than 15 dollars at Lowes, home depot, or anywhere that sells halogen lamps.
Posted on Nov 18, 2008
  • Rick Kasper Nov 19, 2008
    Yeah, when installing the registration transport you most likely broke the sensor actuator.
    Very easy to do.,
Scanner error 02
Go To Below official Epson Printer Page For Your problem, Product Status Messages Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Apr 13, 2014 | Epson Office Equipment & Supplies
Printer error 59.99
Hello thanks for using Fixya
This error mostly occurred in the secondary transfer engaging mechanism. This error may be because of following reasons
  • If Fault is in secondary transfer engagement sensor then Replace the secondary transfer engagement sensor
  • If fault is in secondary transfer engaging solenoid then Replace the secondary transfer engaging solenoid.
  • If fault is in feed motor then Replace the feed motor.
  • If fault is in DC controller PCB then Replace the DC controller PCB
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 25, 2011 | HP Color LaserJet 3500 Printer
Getting fault error 37,008.44:31508 How
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Oct 20, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Error 41
error 41 is a printhead fault. The only repair is a new printhead. The price went up this year so a new one will cost you at least $89.00 plus labor.
Jul 29, 2009 | Brother MFC 3420C All-In-One InkJet...
I get this error 09.038.46:16890, Xerox 8560
9038 Means that the inck count sensor flags are stuck after melting 2.5 ink sticks for your black ink. Are you running Genuine Xerox Ink? If so then you need to run the "Clear ISC Fault" test to clear the error. This is done in the diagnostics menu. To get to the diagnostics menu shut your printer off then do the following.
1.) Hold down the back and info buttons
2.) while holding the buttons turn your printer on
3.) keep holding for 30-45 seconds
The "Clear ISC Fault" is located under the Functions menu.
After you have run the "Clear ISC Fault" verify that the black ink sticks are able to advance in the ink loader chute. Check and make sure there are no broken ink sticks or wrong ink types and remove them.
Mar 19, 2009 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Cannon D780 All in One Laser Printer System Error 000
System error 000 means a fault occured 4 times in a row. You can reset this fault code and the copier should start working again. I assume you had other fault codes before you received this one, otherwise you would of never got the 000 code. To reset this code, you need to go into service mode. I dont have the instructions at this very moment, but I will get them and post them tomorrow.
Oct 05, 2007 | Canon imageCLASS D780 All-In-One Laser...
Xerox Phaser 8200 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
