Question about Uniden Cordless Phone
Uniden Model EXP7900 How do I program button m1
How do I program button m1?
  • 126 Answers
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Posted on Dec 18, 2008
Have Uniden XS910 phone - older model - white. Message Bank was set as M1 (speed dial). Now not working. All we get is an engaged tone. How to reset please. Is the problem the phone or i'net provider?
When was the last time you checked the battery that keeps the memory alive? It's the same as your computer if it won't startup properly - it has a battery, like so many thing now-a-days
May 22, 2017 | Uniden Lands Phones
My scanners hasn't been turned on for sometime and wnat to program it but scanner is stuck on one channelBearcat Uniden 800Megs.police scanner model BC 855 XLT..
It used to be that you could reset a Uniden scanner by holding down the #2 and #9 buttons while turning on the radio - that MIGHT do a factory reset for you. Let me know.
May 07, 2014 | Uniden Radio Communications
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Phone dosen't connect
check the phone settings for the connection
Mar 05, 2011 | Uniden EXP-7900 White 900 MHz Cordless...
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
Binatone 0121 Trend programming
I just checked this out.
1. Press STO
2. Key in the number
3. Press STO
4. Press MEM
Apr 25, 2010 | Lands Phones
Need to erase numbers stored on speed dial
Go to uniden.com and look in customer service/manuals. They may have it to download. You'll need the model #
Mar 26, 2009 | Uniden Cordless Phone
UNIDEN EXP7900 NEW BATTERY CHARGED, GREEN STATUS LIGHT ON, BUT CANNOT GET A DIAL TONE. THIS WAS AFTER THE PHONE HAD BEEN UNPLUGED FOR ABOUT 3 DAYS.
I have a Uniden DECT 6.0, 2 handset phone. I charged the batteries twice for at least 15 hours. I usually unplug the base at night and plug it back in in the morning. Both the phones lose their charge overnight. My old Uniden phone never lost its charge. Is this because the new batteries are smaller than the old ones? Are the batteries bad? I bought this phone from Ebay who said this was a brand new phone, box never opened. Thank you.
Nov 16, 2008 | Uniden Lands Phones
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
264 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
