Question about Panasonic PT-51HX41 51" Rear Projection Television
Colour convergence I recently had a repair man in and he changed the two output cu's and it didn't work so he said it could only be fixed by replacing the motherboard. The problem was with the blue, but then he left and I tried the blue again and got it lined up and it worked fine. An hour later I turned it off and left, when I came back I turned it on and the red colour is is now the problem. Is it the whole board that I have to replace for $550 + labour, or am I getting screwed????
  • Rod MacLeod Oct 03, 2006
    It was the convergence ic's that he replaced and when it did not work the repair man put back in the ic's (STK....) that were in the T.V.
    It was the convergence ic's that he replaced and when it did not work the repair man put back in the ic's (STK....) that were in the T.V. This is a Panasonic 51HX41CE.
    Problem Solver:
  • 13 Answers
If you are not comfortable with desoldering/soldering STK or any electrical board components, I would find you a repair place that would fix your convergenece issue. Some will come out to your home ($65 plus just to come out) and other will take just the board and repair at reasonable not to exceed $400.
Posted on Dec 20, 2007
Toshiba 43VJ22P, the colours blue and red go in double vision, tried convergence didn't work. can you help please?
You will need to replace the Convergence ICs ,they are Big Black ICs and will have part number on them. Example STK392-110
Mats Electronics has Parts 1-800-628-1118
Jun 30, 2011 | Toshiba 43A10 43" Rear Projection...
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
I need the convergence code or how to get into the menu to converge my rca p52939 colours are not aligned
Hello,On your remote click the menu button and then go to the screen adjustment section. Once there chose convergence, and use the simple cross pattern to try to adjust your settings. If this does not work then you may have a convergence amplifier problem. For that you will have to have the convergence ICs replaced. I would suggest that you get a qualified TV repair man to do this for a fee. There are many instructions on how to do this on-line.I hope this helps,Regards,Shuttle83http://www.electron-age-technologies-llc.com
Jun 09, 2009 | RCA P52939 52" Rear Projection Television
The covergence
I have a kp-61v90. I love this tv. Recently the flash focus isnt working,,,,, the colors are not lining up to give me a solid cross in the middle so it makes everything look as if i were wearing 3-d galsses. Yes i can solder, but what am i soldering. Help me please....my man cave is out of commission.
Mar 06, 2009 | Sony KP-61V90 61" Rear Projection...
First color alignment problems then no pix or sound, just chirpin
If the unit is chirping your convergence amps are out again,or you have a shorted Horzontal output transistor. Not likley for horz output to go out after convergence repair. If he did not replace the 6.8 ohm resistors along with the convergence amps the convergence amps would overheat and short out again.This would explain why the corner would not adjust out. Not a very good buisness practice on his part.Here today gone tomorrow?
Jan 15, 2009 | Philips 60PP9202 60" Rear Projection...
Samsung tv #hcm5525w is on but has double vision
The problem sounds like it is the convergence output ic's are bad. I would let a repair man fix it.
Nov 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Color convergence alignment
change your convergence ICs that should solve your problem.If you need more info let me know.
Apr 08, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
