I have an old Russell Hobbs Coffee Perculator model 3010 desgn no.976770 I need a new electrical lead
  • fanwe Nov 06, 2008
    Coffee pot section was the first place I tried but it offered no information on spare parts.
It's a standard IEC C15 plug, known as a "Jug Plug." It's the same as the standard C13 plug, but has a ridge to prevent a C13 being inserted.
C13 connectors are rated at a lower temperature than C15, so C15 are used for kettles & similar. A C15 can be used in any situation.
Avalable at any electrical parts store or electrical retailer.
Posted on Dec 07, 2008
    Scholar:
  • 195 Answers
Have you tried the Coffee Pot Section? Good Luck.
Posted on Nov 04, 2008
My gateway profile 4 all in one has a totally white screen with no display. Rebooted with normal
before thinking about replacing the video card
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you need to replace the video card it will be attached to the rear of the vga lead inside your computer usually in a pga slot
Remove your computer's cables.
Turn your computer around so the back faces you.
Remove the two screws on the computer holding the right side of your computer to the case.
On many models of gateway computers, you only need to remove the screws with your hand. Remove the right side of the case to expose the interior.
Unscrew the metal plate of your old graphics card holding it to your computer's case. Remove the card by sliding it out of the motherboard.
Slide your new graphics card into the slot from where you removed the old one. Screw the metal plate to your computer's case.
Reassemble your computer and connect its cables
hope this helps
Aug 02, 2012 | Gateway Profile 4 All In One (MPN...
Hi, Power supply died in my 10 year old computer. I put in a new one. The motherboard M6 STL light comes on. The cpu fan runs. The CD door opens and closes. That's it. Please help. Bruce
Possibly the power supply died whilst and caused damage to the system board or video board.
Have you still got the system board manual with the "Beep codes"? that will tell you which area to look. It is likely the video board has crashed.
Hope that helps.
Nov 27, 2011 | Clone Computers & Internet
Emachine w3107 has been restored to factory default worked but now it the monitor is black
Test all leads that attach to your hard drive including electrical extensions EIDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure dust free connections and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or
just replace them they could be faulty a computer needs all power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
you might have a dirty graphics card if you remove your graphics card restart your computer then
hope this helps you
Nov 04, 2011 | E-Machines eMachines Desktop PC
I turn on power to tower and nothing happens sometimes it sounds like ti is going to work the nothing
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 26, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
The screen goes whie blank
Feb 25, 2011 | Computers & Internet
No power
hope this will help
don
Feb 24, 2011 | Computers & Internet
Blinking orange light want pown on
hope this will help
don
Feb 19, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
HDD No Detected
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
hope this helps
Jan 13, 2011 | Computers & Internet
I can't switch on my computer. There is no beep sound, all fans are turning on. mother board light on. hard disk as well. but no signal is sent to the screen. this happen because i change the processor...
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 18, 2010 | Computers & Internet
Open Questions:
Computers & Internet Logo
142 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
