Question about Samsung Refrigerators
Samsung SRL 3426BS fridge/freezer, cool n cool. It is bleeping, sounds like life-support machine and driving us all mad. Saumsung were most unhelpful, stated I could obtain a handbook off website but there doesn't appear to be one for this model. Bleeping phobia is coming close. Any ideas???
  • 3 Answers
SOURCE: Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Posted on Nov 17, 2008
SOURCE: Samsung cool n cool fridge
fridge is not getting cold freezer is ok
Posted on Jan 26, 2010
  • 378 Answers
SOURCE: my fridge will not stop bleeping and keep showing
may be the door ajar switch is not working or is jammed. Just look at the edge of the door that is hinged. You will find a switch which is pressed when the door is closed. Just manually press and release it few times. If things do not change, call a technician
Posted on Apr 01, 2010
daniel_mir
  • 3 Answers
SOURCE: samsung SRL39288 Cannot turn a bleeping sound
Hey, heard you guys are quite good.
I have a problem with my Samsung SRL3916BSS. There are 5 lights thats be solid but only one light is on and its flashing (its the first one)
I hope that you can help me with this problem.
Can you please respond to my Email : daniel_mir@hotmail.com
Posted on Jul 27, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Samsung fridge/freezer
From your observations it seems that the compressor and fridge/freeezer functions are not very much affected by the erratic display seen on the panel. So it seems more likely that the display section, the processor section can be suspected.
Now the most possible chance is that the electronic display can be the main suspect as you have mentioned that the freezer works irrespective of the display shown.
Remove the display unit and make sure there is no chance of moisture in the PCB, the connectors or the main board. Use a hair dryer to warm up if in case you suspect. Use a soldering iron to touch up soldering that seems suspected of a faulty joint( dry)
If these services wont solve the issue the possibility of the display or the mother board sections having errors is possible.
Posted on Dec 04, 2010
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Samsung Cool n Cool upright fridge freezer bleeping constantly, both fridge and freezer working OK
Oct 01, 2015 | Samsung Refrigerators
My LG Fridge freezer GBB539PVQWB is bleeping when door closed switched off and back on still bleeping driving me mad
Put your hand up the chute where the ice comes out and see if that flapper door is stuck open
Feb 15, 2015 | LG Refrigerators
Is there anybody on here that could tell me what's up with my fridge freezer please?we have tried turning it of and on again and resetting it and it just keeps bleeping at us or bleeping and turning off...
Hi Zoe, the beeping is a sensor to indicate the door is open allowing room temp to enter, check the seals around the door are clean and intact.
Sep 02, 2014 | Refrigerators
Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Mar 26, 2009 | Samsung Refrigerators
Samsung fridge freezer
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 30, 2008 | Samsung Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
44 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
