Question about Dryers
The tumble dryer appears to be working aand heating up. However after a short amount of time the reset button pops out and the tumble dryer continues to tumble but with no heat. If you press the reset button the sequence starts again.
  • DebbieConnel Nov 05, 2008
    We have checked both of those and both are fine. Do you have any other suggestions?
More than likely, your LG dryer is experiencing a lack of proper airflow. If the venting isn't clean & clear the dryer cannot circulate air in & out of the dryer. This leads to long drying times and premature ending of the cycle. I specialize in dryer vent cleaning and have seen many LG dryers with the sdame issue. A customer called the other day with a similar problem and the airflowreading using a vane anemometer was 366 feet per minute before we cleaned their 14 foot vent pipe. The airflow after the cleaning was 1095 feet per minute! Now their new LG will function as ai should. If necessary call a professional to handle the vent cleaning.
VENT SAFE Safe Dryer Vent Cleaning
Port Charlotte, Florida
Posted on Feb 09, 2009
Resettable stat could be operating at wrong temp but would still look for a blockage in the air flow. also check that fan is in fact working. if this is a condensor dryer, check the condensor is not blocked with lint
Posted on Nov 05, 2008
    President:
  • 1,462 Answers
Check the lint filter and check venting clear
Posted on Nov 04, 2008
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
White Knight tumble dryer making a clicking noise when on & has no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
May 02, 2009 | Dryers
Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
Dryers Logo
520 people viewed this question
Top Dryers Experts
