Question about Canon PowerShot G5 Digital Camera
Canon G5 Menu and function do no work
I mave a canon G5 powershot.It takes pictures and the LCD is working but but the menu ,Set buttons do not work. The setup screen comes on and freezes. set or menu buttons will not change it. I switch to camera mode and press shutter release to clear the screen
SOURCE:
  • 130 Answers
SOURCE: canon powershot a610..pictures come out black..
When you say the shutter is open, you can see the purple glass lens from the front?
Posted on Apr 23, 2006
old marine
  • 2237 Answers
SOURCE: turning af beam off
The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
Posted on Apr 21, 2008
SOURCE: G5 Powershot Cannon
I posted this on another link to this site where they were having the sam eproblem so this may work for you.
OK, I think I worked it out. The shutter button was not working correctly. They wanted at least $182 to ship it off to a Canon repair facility. Give me a break! My husband spilled coffee on his personal laptop and then several weeks later spilled juice on his work laptop...I'm thinking...hello...learn any lessons yet. Anyway, he couldn't get the keyboard to work properly on his personal laptop (apparently it didn't like all the caffeine) so he bought some Precision Electronics Cleaner at Radio Shack and tried to clean it. That didn't work so we had to order another keyboard. But, that gave us the idea to try the cleaner on the shutter button. The button worked fine in the half way down focus position so we figured the spring under the button was still working but the contact when you pressed it all the way down was not activating the shutter. If we jiggled the button a bit it would take the photo so that meant the contact needed cleaning in order to take a picture with out mashing or jiggling. So short story long, I sprayed some in there and then blew some air into it to dry it out a bit quicker. The spray evaporates anyway, but that just sped up the process. It works like a charm now!!! YEAH!
Let us know if this helps. Good Luck!
Colleen
Posted on Jun 29, 2008
  • 310 Answers
SOURCE: No image. The menue (etc.)
On the display button...See catalog properly....
Posted on Jul 09, 2008
jcdill
  • 121 Answers
SOURCE: Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
Posted on Jan 11, 2009
Canon a2200 screen
The LCD screen inverter maybe faulty. Take your camera to the Canon repairer to have the camera fixed.
Apr 06, 2013 | Canon PowerShot G5 Digital Camera
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
I can see the menu and icons on the LCD screen,
It is known problem of ccd imager failure in S3IS Canon camera and ccd imager chip will be replaced to get live view to take fresh picture.
Local camera repair shop will repair camera by replacing ccd imager chip because camera will take apart and soldering work is also involve so its not likely novice fix.
Thanks.
May 30, 2010 | Canon PowerShot S3 IS Digital Camera
How to seup date and time on the screen when we
Hello Dear,
In all Canon PowerShot and IXUS series cameras date and time can be stamped on the photos shot in Post Card Size, to set the Camera into this mode do the following:
On Camera in Shooting mode (Live view is visible on LCD)
Press Function/Set button once
From right-left move to the Post Card Size
Press Function/Set again.
Now, Press Menu Button
From up-down move down
On Stamp Date (Option Name written, Visible on the Right top Corner of Screen)
From right-left move and select you want only Date or Date and Time both.
Press Menu again
Now, you are ready.
For more clarification please revert.
Warm Regards,
Joseph Manoj
May 22, 2010 | Canon Cameras
Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Jul 01, 2009 | Canon PowerShot G2 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon IXUS 500 menu problem
You can access these functions from Manual mode. Press the "func. set"-button and change the camera mode to "M"
Nov 05, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot G5 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
