Question about Zenith Z09P02X 9 in. Television
Sizzling noise When I plug it in and try to turn it on I hear a sizzling noise for a few seconds and then it stops. Almost sounds like a cap charging but I can see no obvious damage.
  • 24 Answers
Sounds like the High Voltage section is shot. Probably a bad flyback transformer. This is the component that has the high voltage lead coming out of it. There is no high voltage to the tube and no picture as well. The horizontal output transistor is usually a suspect here as well if its shorted. Hope this helps.
Posted on Nov 16, 2006
SOURCE:
The ice maker quit a few months ago (water still works) but I hear dripping into the drip pan.
sounds to me that ice tray fill tube is broken in the back as it runs up from the bottom to the tray , could that be the source of the sound of running water u hear ??? ill bet its intermittent , say 30 sec every two hours ??? and it stops making sound if u turn off ice maker ??
May 04, 2016 | KitchenAid Superba KSCS23IN Side by Side...
Sony google tv makes sizzling sound
Even after switch off, there can be some discharge of static charges present in and around TV, hot plastic parts can contract and make some noise. Some sets have the cooling fan run for a few seconds more to reach a particular temp, before it is turned off. Just try switching off the power outlet, and removing the plug and see.
Aug 19, 2012 | Sony Google TV NSX-32GT1 32 in. LCD HDTV
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
97 Dodge 2500 will not start
see if you have fuel getting to the injectors
Dec 07, 2008 | 2001 Dodge Ram 1500 Truck 2WD
Gone in 60 seconds
Seems to be a problem with your power supply. Contact your manufacturer for a new one. It won't be expensive
Jul 22, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Televison & Video Logo
174 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
