Question about Dishwashers
Simply put, my dishwasher will not drain - Dishwashers
  • Anonymous Feb 02, 2009
    I have model SHE46C...my first dishwasher....and it has worked fine for a year...however, tonight it did not drain. I scooped out the water and removed the filters but nothing in it. I am not sure what to do.
    Sergeant:
    Champion:
  • 324 Answers
What model? could be the chopper or something in your check valve,depends on the model.
Posted on Nov 04, 2008
Clean the drain screen
It is best to keep your drains clean. Simply put. If you want to clean that drain screen, you can remove it. I suggest using vinegar to sanitize it. That way you don't run the risk of wearing down the finish.
Elisa Jed ' http://www.mcdermottplumbing.com/sewer---drain-cleaning-service.html
Apr 09, 2014 | Miele Premier-Plus Built-in Dishwasher
Lights are flashing with OE flashing stopped washing
OE is a drainage problem. Check all lines, and drains for kinks.blockage. Ours was blocked in the T connection where the drain goes into the sink( in the black ABS sink part.) Used a screwdriver to simply clear the t connection with the drain hose disconnected.... ran the DW( where it fills w/ water) ,then turn off, and put the drain hose into a bucket... if its pumping water out well, then it could be the sink drain.
If not... a line somewhere is plugged.
Nov 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
I installed a new food grinder under the sink. I also replaced the dried out rubber hoses that connect the food grinder to the dishwasher. But no matter what program I use, the dishwasher refuses to drain...
Check to make sure you removed the plug inside the garbage disposal inlet where the dishwasher drain hose connects. This is a common mistake installers make when installing a new garbage disposal. Make sure the power the the disposal is secured and remove the drain hose. Place your finger inside the inlet on the side of the disposal. The opening should be clear. If not, you simply need to insert a flat blade scewdriver through the inlet connection and tap out the plug with a hammer. The plug will pop out inside the disposal, so you will need to reach inside and retrieve it before attempting to use it. Once the plug is removed, reinstall the drain line and test operate your dishwasher by starting a cycle. Once the dishwasher fills and begins the wash cycle, press the STOP/CANCEL button to initiate a drain cycle. Your dishwasher should drain with no problems. If you have any questions, please post back and let me know. I hope this helps you.
Nov 19, 2010 | Whirlpool Dishwashers
Our dishwasher will not drian out all the way. I cleaned out the screen and sump and it still does not drain out all the way. I also ran the unit and waited for the drain cycle and it seemed to flow...
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain, the largest percentage of them were simply because of a clogged drain hose or pump strainer. Too many people seem to think that the dishwasher is first cousin to a garbage disposal. It is not.30 Apr 2010
SOLVED: Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
Nov 29, 2017 | General Electric Dishwashers
Dishwasher will not drain
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Mar 20, 2010 | GE Nautilus 24" Built-in Dishwasher
I have a Bosch dishwasher that was working just fine until I spilled a bag of uncooked pasta. I sent the pasta down the drain and ran the garbage disposal, subsequently clogging the pipes. I had to get a...
It may simply be where the dishwasher drain attaches to your garbage disposal. There should be a hose clamp and can easily be taken off. If the clog's not right at the connection, chances are it's far. If there is an air gap, it will be within a foot of the connection. Just shake the DW drain into a bucket and you should be good to go. Not sure why the plumber wouldn't do that though....being a plumber, I would never leave a customer with a clog. Anyway, good luck!
Jan 24, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwasher wont drain
Depending on the age of your dishwasher, it could be either a directdrive or forward reversing type. We've had both. Direct drive dishwasherssimply keep going as the water drains but forward-reversing ones havemotors which stop and then start (moving in the opposite direction) todrain water out of the dishwasher. It helps to know what type ofmachine you have. Obviously, if the motor isn't reversing properly,that could be the cause of a problem right there. But let's hope thatis not the case.
Next, think about whether you've installeda garbage disposal recently and if the dishwasher stopped drainingright after you installed the disposal.
Many dishwasherswon't drain or seem clogged after a garbage disposal is added to thesink area. Happily, this is not only a common problem but one which isusually resolved quickly. You'll simply have to check a piece calledthe knock-out plug. You can see what that looks like here: www.applianceaid.com/food.html#plug
Okay,so was your disposal installed without taking out the knockout plug?Oops! Simply remove it and you are good to go. Your dishwasher shouldnow drain smoothly. Simple.
Jan 09, 2010 | Kenmore 24 in. 17532 Built-in Dishwasher
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
Dishwasher won't drain
Hi! You have not mention about mfg and model No.
Jan 15, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
