Question about Plantronics - Bluetooth Headset Plus Base & Headset
Winamp/bluetooth/plantronics p590 How can I get winamp to send music to my plantronics p590 via USB bluetooth adapter? (KB-A100)
I have found that winamp doesn't automatically output through any hands-free headphones, therefore you need to go into Preferences on Winamp (Ctrl+P), go to:
-Plugins/Output
-select Nullsoft DirectSound Output -->configure
-select Device tab
-select 02: Bluetooth Hands-Free Audio
-click apply
If music is already playing, click STOP then PLAY, pause will not do it.
I have been looking for this fix all day on the internet, but finally worked it out myself.
Hopefully this post will make someone else's day less stressful!
Posted on Jun 24, 2009
Using Windows Vista, open Bluetooth devices (just type in bluetooth devices into the search bar) then click on Add, put a tick in My device is set up and ready to be found > click next > double click on 590Plantonics > then next > put a dot in Use the passkey found in the documentation > type in 0000 then click next. It will then install the drivers, and click finish.
To ensure all windows Vista audio goes through your newly setup bluetooth headset, click on Start > Control Pannel > Sound select "Speakers: Bluetooth Stereo Audio" > Click on Set Default.
Now all windows applications will play through your headset. Your system will revert to it's normal audio once your bluetooth is disconnected.
Posted on Jun 10, 2009
I just got this and it is used I would like to up load music to the mp3 620 I just don't know how it has no manuel
you should download winamp free from winamp.com it has an easy user interface and when that is done connect your device with the usb cable you should have gotten with your device. your mp3 player will show up on the left side of the winamp program.
Feb 16, 2011 | Coby MP620 MP3 Player
I forgot how you put music on.Could anybody be ale to tell me?(I lost the book some time ago so I don't know that.)
well the easiest solution is to download winamp free from winamp.com and it should recognize your device at the bottom left side of the winamp screen. if that doesn't work you can manually put songs on by dragging them from your computer to the device via the startup menu-computer and then double clicking your device and looking for the media or music folder. i would suggest trying winamp free first.
Feb 15, 2011 | Mach Speed TRIO Onyx MP3 Player
Downloading music from pc to mp3
Download Winamp, from winamp.com. You can do all those things with it. More specifically, if you have winamp and you've inserted your CD and your MP3 player, you'll be able to see both in Winamp's Media Library. Then, it's as simple as a "right click" on the CD, clicking on rip audio CD, finding that music in your local library, selecting it and sending it to your mp3 player.
Jan 18, 2010 | Audio Players & Recorders
Plantronics p590 + BB Pearl
Pearl 8100 can not output media audio to Bluetooth. Another BB might.
Sep 12, 2008 | Plantronics - Bluetooth Headset Plus Base...
Need help for sound card driver!!!
Try reinstalling both winamp & direct x.
Does this fix the problem?
Aug 02, 2008 | EliteGroup P4VMM2 Motherboard
My wbt210 is looking for signal. The usb and computer it is plugged into have found wbt210.
right click your sound settings in the task bar and make sure its not turned down or muted
Apr 02, 2008 | Jensen WBT210 Consumer Microphone
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Love the system...
The e-mu sure can do it. You just run whatever output you want into the input on the sound board. The setup is exactly the same as if you just wanted to play winamp music on the system.
It's your computer that can't handle it. Computer only has one sound output, so you can't play two separate things in two separate instances of winamp, because the sound only comes out of one place on your laptop.
You can buy a second external sound card, like the SB Live External USB Sound card, and maybe run both at the same time, having one winamp output to the external device, and the other winamp output to the laptop's internal sound card device, then one line runs to your e-mu system and the other to a pair of headphones.
Or you can bring another laptop in ;)
Jan 21, 2008 | E-Mu 1616M Sound Card
I have no idea what to do! help!
To sync your device use either winamp or Iriver plus (winamp is better)
-Download winamp from http://www.winamp.com/player
-Iriver plus http://www.iriver.com/support/down_view.asp?idx=860
All firmware releases for your H10 can be found at: http://www.iriver.com/product/p_detail.asp?pidx=61
Jan 05, 2008 | iRiver H10 MP3 Player
Plantronics - Bluetooth Headset Plus Base & Headset Logo
912 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
