Question about Video Game Consoles & Games
My xbox is showing no signal on our television and have tried everything, what else can I do?
  • timclarke May 11, 2010
    when you say you've tried everything ;)
    Have you tried:
    -a new lead from the back of the xbox to the tv?
    -the same xbox on a different TV?
    -Making sure that if you're using AV or SCART that you're looking at the right channel on the TV?
    Also:
    Is this an xbox or an xbox360?
If using a 360 make sure if you have hdtv or a non hdtv that you check the switch on the av cord and leave accordingly to your tv type also make sure you have your tv on the correct input if using 360 or original xbox
Posted on Nov 07, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
Proscan tv
Check that you're on the correct input and the Xbox 360 is sending the correct signal (be it 720 or 1080).
Sep 08, 2014 | Proscan Televison & Video
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
Xbox 360 won't show cuz of s-video
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Mar 06, 2009 | Microsoft Xbox 360 Arcade
My xbox 360 wont recieve a signal from my computer.
if your laptop get a signal than buy a eithernet cable and coonect your xbox 2 the laptop and go 2 your network settings and check the box that say share connection than wait a few mins. and try to connect to xboxlive this should work because thats how i get on xboxlive at my house.
dalvon78@yahoo.com
Jan 05, 2009 | Microsoft Xbox 360 Console
Rear input connectors
Does it give you a "No Signal" on the screen, you may have to check the xbox and make sure you have it setup to output a HD signal. Let me knwo what you find.
Oct 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
No Input Signal From My Xbox360 In HDMI or Scart?
Connect the xbox to anothe source and make sure the resolution is correct on the Xbox. If so and the set is in warranty contact Philips @1-888-744-5477 and have them take care of the repairs under warranty.
May 23, 2008 | Philips 42PFL5332D 42 in. LCD Television
TOSHIBA 57 H 81 wont play 480p any more Green Screen
this happened to me once and what i found was that i had missed a defective component.. these parts need to be checked for ESR also check the solder connections....john
Aug 24, 2007 | Toshiba 57H81 57" Rear Projection...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
