Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Sewing forward my machine is pushing the fabric, insead of pulling. is there any way of fixing this.
  • gkang Nov 14, 2008
    I have Kenmore 16221 sewing machine and have the same problem. Fabric moves toward me rather than away. I tried the reverse button and still won't work. Whan do I need to do?
  • MmbMjb Jan 17, 2009
    I'm having this same problem. But when I use the reverse button it will change the direction that my fabric is going so it is working right. Have you been able to fix this problem?
  • Kenmore Master
  • 1,388 Answers
Sounds like the timing has been adjusted to be 180 degrees out of sync if fabric moves towards you while sewing, rather than away.
Posted on Jan 27, 2008
SOURCE:
The feed dogs on my brother sewing machine is not moving the fabric. It will move it if I sew in reverse but not forward. What could the problem be? How can I fix it?
Um. A feed dog pretty much always moves fabric forward. Only time I can think of that it doesn't ...you might need to push down the ...had to go down the hall and retrieve my machine's manual.. Forgot the name of the parts. On top of the left end of your machine, press down on the 'darner'. Knob on the top of that side of any machine. It regulates the pressure on the top thread. It thinks I'm not being clear, but it is 4:30 am.
Jan 22, 2018 | Brother Sewing Machines
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
Pressed pedal and machine won't go push fabric forward
Hi, I have a Poiedent sewing machine and its needle is not going up or down.Can you plz give me a solution to fix this problem?
Feb 13, 2014 | Kenmore Sewing Machines
Kenmore 148 19371
Raise the feed dogs, a manual may be helpful if you don't have one.
Fix Machines here is a link to a manual you could purchase. Also, remove needle and clean out the groves of the feeddogs.
Jan 14, 2014 | Sewing Machines
Feed dog not moving fabric forward
it would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
Jan 07, 2013 | Brother XL-6562 Mechanical Sewing Machine
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Feed Dog
Is it in the button hole setting? If so that could explain it.
Jan 17, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
61 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
