Question about Sharp AR-M205 Copier
My Sharp Printers Again
This time,they are displaying an error code:H2-00 and also H4- 00. So please help me out once more, please.
  • Clement Oluwapelumi
    Clement Oluwapelumi Nov 04, 2008
    Sorry, I don't Understand what you mean by that. Please can you explain further to me so that I can get it clearer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
You are having a problem w/the fuser unit, w these units they usually replace the whole fuser, but check the themofuse or lamp.
Posted on Nov 04, 2008
  • CheckitRight
    CheckitRight Nov 04, 2008
    the fuser unit is where the paper comes out and it gets HOT, the heat lamp may have blown out or the thermofuse ( which is a regular fuse but for heat) has blown.
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
Halkawt_07@yahoo.com
 have a Sharp AL1540CS MFM. It has been displaying the H4 code for a while. Clearing it would work for a time. Removed the fuser assy., and cleaned the temp sensor. It had a wad of toner stuck to it. Cleared the code again, so far so good.
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
HELP, H4 ERROR
H4 is normally caused by the fuser taking a little longer than normal to warm up. Most of the time it is not caused by the hear rod itself. I will send you the process here is a few minutes.
Jul 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Sharp AR-M205 Copier Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
